Old 05-22-2015, 07:12 PM   #2426
gdavis
gdavis's Avatar
Re: 1968
Today I hooked up all the stuff under the truck. Almost. I got the transmission lines and the started. I'll do that tomorrow. It getting a little closer to cranking up the engine for the second time.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 05-29-2015, 08:58 PM   #2427
gdavis
gdavis's Avatar
Re: 1968
Today I hooked all the stuff in the engine compartment. all went well. I started the engine and I need to adjust the drivers side valves again. Or see what is the matter with the lifter. I have one that is tapping. but the engine runs good. I took it for a test drive today. and it felt good to drive the old girl.
Check out Patches
Old 05-30-2015, 02:11 AM   #2428
swamp rat
swamp rat's Avatar
Re: 1968
Success! Congradulations George!
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 05-30-2015, 02:55 AM   #2429
Xeen
Xeen's Avatar
Re: 1968
George I know you are an old hand at this but give this procedure a try and see if it helps you at all.
http://www.speedwaymotors.com/Tech/h...cam-valve-lash
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 05-31-2015, 08:56 PM   #2430
gdavis
gdavis's Avatar
Re: 1968
Thanks Mr. Swamp Rat. I took the truck out for a test run this Morning. I got about 5 miles from the house and I noticed a lot of smoke coming out from the back. I knew this I had a oil leak. so I took it home and found a valve cover was leaking on the driver side. I replace the gasket with a new one and it was fixed.
Check out Patches
Old 05-31-2015, 09:00 PM   #2431
gdavis
gdavis's Avatar
Re: 1968
That is the same way I did the valve adjustment. But when I cranked it up it had a lifter napping. So I pulled the valve cover off and adjusted the valves again with it running. Now they all is AOK. But hey thanks for the in site and the link. Maybe someone else can use it also. Again thanks.
Check out Patches
Old 05-31-2015, 09:12 PM   #2432
gdavis
gdavis's Avatar
Re: 1968
Today I took the truck out for another spin around town. It failed the first test. But only a small thing. The valve cover gasket on the driver side leaked. No big deal I went to Advance Auto and picked up another one and now it is done, fixed.
My brakes was really hard. so I replaced the rod with another straight one and now they work a lot better. I removed the bracket that came with the new set up. it was binding up the booster. all well now. I then took it out for another drive around 25 miles and boy what a difference that made.
I hope to get it to the front end shop and have the front end adjusted. The last guy could not do it. Here are a few pictures of the truck all finished. I still have a few bugs to work out. I want to set the timing with a timing light and adjust the carb.
Check out Patches
Old 05-31-2015, 09:13 PM   #2433
gdavis
gdavis's Avatar
Re: 1968
one more
Check out Patches
Old 05-31-2015, 10:15 PM   #2434
swamp rat
swamp rat's Avatar
Re: 1968
Awesome!
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 06-01-2015, 12:00 AM   #2435
dfwright
dfwright's Avatar
Re: 1968
It's really looking great George! It's good to know you're getting to drive it around. After all that work, finally the payoff!
1972 C10 LWB, 350/350
Deconstruction began 5/2009, mostly completed restoration, 5/2017
dfwright is offline   Reply With Quote
Old 06-01-2015, 08:42 AM   #2436
zicc1835
zicc1835's Avatar
Re: 1968
congratulations George, thanks for sharing your journey lots of good info along the way and a truely awesome backyard build
jess
zicc1835 is offline   Reply With Quote
Old 06-02-2015, 08:37 PM   #2437
gdavis
gdavis's Avatar
Re: 1968
Swamp Rat, dfwright, z1835 thanks guys. I finally got the truck out of the back yard and parking it in the front. I had to put a piece of 3/4 '' plywood in the bed. State Farm insurance said that I needed a bed floor before they would put insurance on the truck. 22.00 isn't that bad. Later own I will be putting a plank board floor in the truck. Next week I will be taking the truck over to a local shop and he will be doing all the fine tuning on the engine. Timing and carb and valcume leaks if there is any. It has a few issue's but nothing bad. Three years and I don't know how many hours.
Check out Patches
Old 06-08-2015, 05:02 PM   #2438
Dustmaker65
Dustmaker65's Avatar
Re: 1968
Congradulations George! I have read your build from the beginning and am so glad for you to finally get to enjoy your truck = Patches!
Jimmy Hoelzel
Dustmaker65 is offline   Reply With Quote
Old 06-10-2015, 02:36 PM   #2439
gdavis
gdavis's Avatar
Re: 1968
Put a new shifting valve on the transmission but it still shifts hard. It going in the shop tomorrow to adjust the carb and timing. I hope they can tell me what is wrong with the transmission shifting problem. maybe it need some adjusting also.
Check out Patches
Old 06-10-2015, 03:22 PM   #2440
Xeen
Xeen's Avatar
Re: 1968
George refresh my memory did that transmission come with the truck or did you buy a used one or was it rebuilt?
Old 06-11-2015, 08:58 PM   #2441
gdavis
gdavis's Avatar
Re: 1968
the transmission was in the truck when I got it, a th400 and it works great, all it needed was a few adjustment like.
carb adjuster
timing
valcum lines
now it starts great and idles like it should. and the transmission shifts smooth it is a pleasant to drive now.
before it barked the tires every time I put it in gear. I am planning on pulling the 373 rear end gears out and putting in a 308 this week end. I had to borrow a torque wrench, mine was not big enough. I hope this will slow the engine down a little and save gas.
Check out Patches
Old 06-12-2015, 03:45 AM   #2442
Xeen
Xeen's Avatar
Re: 1968
That's great George, I'm glad to hear it's all dialed in.
Old 06-16-2015, 12:13 PM   #2443
gdavis
gdavis's Avatar
Re: 1968
Got the truck from the shop a few days ago. Boy what a difference a little adjustment made. I got a new temp gage, I didn't like the elect one. I will install it when the engine cools down a little.
Check out Patches
Old 06-16-2015, 12:14 PM   #2444
gdavis
gdavis's Avatar
Re: 1968
Thank bryan
Check out Patches
Old 06-25-2015, 11:20 PM   #2445
WIDESIDE72
WIDESIDE72's Avatar
Re: 1968
Glad to see you got her going!
WIDESIDE72 is offline   Reply With Quote
Old 06-26-2015, 09:28 PM   #2446
gdavis
gdavis's Avatar
Re: 1968
thanks wideside72 it just turned over to 750 miles on the new engine.
Check out Patches
Old 06-29-2015, 12:32 PM   #2447
Low Elco
Re: 1968
Great news, George! Glad to hear you're finally rollin' around in it.
Low Elco is offline   Reply With Quote
Old 06-30-2015, 07:58 PM   #2448
gdavis
gdavis's Avatar
Re: 1968
yea I am driving it all over the place, I got to get a new door seal for it leaks around the top on the drivers side. This was the first time I drove the truck in the rain. George
Check out Patches
Old 07-02-2015, 11:35 PM   #2449
mattfranklin
mattfranklin's Avatar
Re: 1968
That's a great looking truck!
(Very) Slow-Going Build Thread: Stock 1970 Short Step with Stock 1970 LT-1
http://67-72chevytrucks.com/vboard/s...d.php?t=567340
mattfranklin is offline   Reply With Quote
Old 07-03-2015, 10:08 PM   #2450
gdavis
gdavis's Avatar
Re: 1968
thanks/ it turns heads no matter where I go.
Check out Patches
