Old 05-30-2015, 05:56 PM   #4
hugger6933
Re: Front Disc Conversion and all 5 lug conversion
The square body stuff will work to change you over to disc brakes and power steering[as far as the box goes, you need short pump brackets for the power steering pump]. You can also adapt the brake booster and stuff pretty easily. Now the rear could be used from the parts truck with a conversion kit for less than $150 to put the rear in the older truck but you may be able to either buy axles and brake drums for your rear end or get one from a 71-2 truck they were all disc front 5 lug truck[speaking only in terms of 2 wheel drive]
hugger6933 is offline   Reply With Quote
1968, 5 lug, brakes, conversion, rear axle
