Old 05-31-2015, 05:13 PM   #1
johnyoung
Engine revs up when starting
Fellers I have a real problem on my hands. 09 - 5.3 out of a 2 wheel drive chevy , brand new motor and trans with 900 miles on it. Install went great in my 67 SB pickup. Problem is when I start it up it revs to about 3000 rpm's then slowly comes back to idle. It even does it when I stop and put it in park and rev her up a little - I called the guy that does my harness's and computer and he has never heard of this. Replaced the throttle body twice - no change. Any ideas will be greatly appreciated.
johnyoung is offline   Reply With Quote
Old 05-31-2015, 08:43 PM   #2
aknovaman
Re: Engine revs up when starting
Tune air flow startup tables are not correct for your engine and need adjusted. Another possibility is you have a vacuum leak that the initial startup opens the iac then closes it to compensate for the added air from the vacuum leak to bring the rpm down to the commanded idle speed.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 05-31-2015, 09:21 PM   #3
johnyoung
Thanks for the help. I will check that out tomorrow. I need to show some pictures of our install as it is really nice and clean. Looks like it came in there from the factory. Anyone else have any ides just put her on here. I appreciate the forum as it's everybody helping out. One person here told me Chevy had problems with the 08,09 model motors with PCV valve and another guy said EGR valve. Motor sat since 09 until started about 4 weeks ago.
Old 05-31-2015, 09:31 PM   #4
aknovaman
Is there a valve on the back of the intake that pops out? Some of the older ones had it. Looks like a turkey button that pops out if there is a backfire. It's on driver back driver side of intake near top. Another thing to try is clamp shut the pcv valve hose and the brake booster hoses. If the issues goes away, you have isolated the problem.
FMCDH GBU and GBA
Old 05-31-2015, 09:52 PM   #5
dayj1
'08 and '09 shouldn't have a PCV valve. Somewhere around 2003/2004 GM went to a fixed orifice that is cast into the truck valve cover. An '09 shouldn't have an EGR valve either. That went away on the truck motors in 2002. You also don't have an IAC valve since that is only for DBC setups and your Gen IV motor should be DBW. The vacuum leak theory is a good one and that's what I'd be looking for.
dayj1 is offline   Reply With Quote
Old 05-31-2015, 10:11 PM   #6
aknovaman
Missed the year. Actually the ecu will open the throttle body servo motor to maintain commanded rpm.
FMCDH GBU and GBA
Old 05-31-2015, 10:42 PM   #7
solidaxel
solidaxel's Avatar
Thanks for the information on the PCV system on my engine!
I have been wanting to ask the question on PCV"s
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 05-31-2015, 10:46 PM   #8
68c10airstream
68c10airstream's Avatar
My thoughts on vacuum leak would be throttle blade would be shut and idle would be above target set point and long term fuel trim would be on the plus side. To be honest I haven't dealt with this scenario in a while but a guess as said earlier I suspect a software issue, but I always worked on stock applications.
68c10airstream is offline   Reply With Quote
