Old 05-31-2015, 09:56 PM   #401
Free Candy Inside
Re: Free Candy Inside: 63 Long Panel Build
Originally Posted by pimpston65 View Post
have you tried moving the striker plate in more?
No. I was trying to do some research on here and didn't come up with much. No idea what the problem is but it drove me insane tonight.
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721
Instagram: jaked937
Free Candy Inside is offline   Reply With Quote
Old 05-31-2015, 09:59 PM   #402
pimpston65
pimpston65's Avatar
if the door is just poked out a bit at the back, the striker plate will draw it in more cuz u will need to push it in more...
pimpston65 is offline   Reply With Quote
Old 06-01-2015, 12:30 AM   #403
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
those triangle wedges on 60-63 will also give you fits.
you can use them to move the door around quite a bit.
the striker plate will adjust a little bit, the nuts are on a captive plate behind the pillar, I had to really soak down the ones on my crew cab to get them to break loose, since they were pretty much rusted in place.
you can also get the bottom rear corner to kick in by loosening the top (door, not body) hinge bolts
this picture kind of shows the backside of the striker plate, so you have an idea of what will move.
I had to do all 3 adjustments on the doors of my crew to get them to line up, lots of trial and error, the key is to get the hinge and wedge bolts just tight enough that you can move the door to the right spot, and then fully tighten them.
Old 06-01-2015, 12:57 AM   #404
thefalconer_88
Holy crap this thing is awesome!
thefalconer_88 is offline   Reply With Quote
Old 06-01-2015, 08:22 AM   #405
Free Candy Inside
Thanks Jonz... I'm going to mess with it some more today. Got me some paint sticks this morning and did some research last night. Hopefully I don't have something slightly off structurally and that's causing my issues.
Instagram: jaked937
Old 06-01-2015, 08:34 AM   #406
Free Candy Inside
Thanks!!! She's a work in progress
Instagram: jaked937
Old 06-01-2015, 02:21 PM   #407
66PANEL
66PANEL's Avatar
Sad day the Phoenix Hill Tavern closed this morning.
66PANEL is offline   Reply With Quote
Old 06-02-2015, 08:56 PM   #408
Free Candy Inside
I saw that online. That's crazy!!
Instagram: jaked937
Old 06-02-2015, 09:03 PM   #409
Free Candy Inside
Managed to get the door back on and working although it's not real good. Probably needs completely rebuilt but it's on for now. Also got the front fenders cobbled on and lower mounts made. Did some other body work stuff. Had to rework the exhaust mounts because the straps broke. Hopefully my new mounting idea works. Also started working on the floors but didn't make much progress. I did however make an intake out of an old hubcap. The factory intake wouldn't clear the hood with a 4" channel.
Instagram: jaked937
Old 06-03-2015, 09:32 PM   #410
65sub
65sub's Avatar
Cool idea for an air cleaner. I like the creativity
Dale
My suburban's Twisted Little Sister
http://67-72chevytrucks.com/vboard/s...d.php?t=655167
65sub is offline   Reply With Quote
Old 06-04-2015, 03:49 AM   #411
pimpston65
pimpston65's Avatar
Just wish the bowtie was straight...
Old 06-05-2015, 02:41 AM   #412
Free Candy Inside
It's a chevy caprice hubcap..... Nothing on those were straight to begin with. Lol
Instagram: jaked937
Old 06-05-2015, 02:45 AM   #413
Free Candy Inside
Did some body work but not enough....decided I didn't care enough to make it perfect because it will never be anyways. I've already dented up the newer bedsides laying it out on stuff. So this happened next.
Instagram: jaked937
Old 06-05-2015, 02:48 AM   #414
Free Candy Inside
Fully painted with 1970 chevy blue..... Teaser pic... There's a couple people on here that will be at the car show I'm going to on Saturday. I'll post more later!
Instagram: jaked937
Old 06-05-2015, 07:50 AM   #415
pimpston65
pimpston65's Avatar
sorry i meant i wish the bowtie was str when you look at it, not turned like you have it. cool idea, make it work...
Old 06-05-2015, 09:11 AM   #416
Free Candy Inside
It's all good! Think it's just a sticker. Was going to pop it off and try to turn it, just haven't done it yet
Instagram: jaked937
Old 06-06-2015, 01:23 AM   #417
Free Candy Inside
The V
Instagram: jaked937
Old 06-07-2015, 12:05 PM   #418
Free Candy Inside
So here's how the paint turned out. Top scallop is 17.5' long
Instagram: jaked937
Old 06-07-2015, 12:05 PM   #419
Free Candy Inside
Another shot
Instagram: jaked937
Old 06-07-2015, 12:09 PM   #420
Free Candy Inside
Drove the truck out to the show
Instagram: jaked937
Old 06-07-2015, 12:13 PM   #421
Free Candy Inside
Even won 2 awards. Won't the lowest award and also won a trophy from a car club for top pick. Club is all VW's hence the bus. Super cool to be given an award.
Instagram: jaked937
Old 06-07-2015, 12:14 PM   #422
Free Candy Inside
Then we threw an after party in downtown Dayton OH.
Instagram: jaked937
Old 06-08-2015, 06:44 PM   #423
Free Candy Inside
Cool pic my buddy took of my truck and his 37 Ford
Instagram: jaked937
Old 06-10-2015, 08:35 AM   #424
66PANEL
66PANEL's Avatar
that is a badass pic!
Old 06-11-2015, 12:18 AM   #425
Free Candy Inside
Started working on the subframe for the flooring today.
Instagram: jaked937
