Old 05-31-2015, 11:46 PM   #1
SierraMtns
SierraMtns's Avatar
Rearend Alignment
My rear end is off a little after installing 6" Hotckis springs. I have a ECE track bar. Its off about 3/8". Would you guys recommend adjusting it or just drive it down to alignment shop?
Driver side.
Passenger side.
SierraMtns is offline   Reply With Quote
Old 06-01-2015, 12:53 AM   #2
Ruscal
Re: Rearend Alignment
If your track bar is adjustable, just go for it. Make sure your truck is weighted at ride height, and then measure just like you did before.
Russ
Ruscal is offline   Reply With Quote
Old 06-01-2015, 01:26 AM   #3
Sklptrljay
Sklptrljay's Avatar
That is what an adjustable bar is for. I used a come along to pull mine into the right position, put the threads where I needed them, and popped it into place. Easy-peasy.
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list.
1972 GMC 4X4 K1500 Survivor - Sold
No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy
Sklptrljay is offline   Reply With Quote
Old 06-01-2015, 07:25 AM   #4
hamjet
hamjet's Avatar
LOL, when I read the title it reminded me of when I was young. the rear tires were always bald from burning out and dad wanted to know why. I said the rear end needed alignment...
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline   Reply With Quote
Old 06-01-2015, 08:31 AM   #5
engineer_gregh
engineer_gregh's Avatar
I would make sure your bed is on straight. Measure the gap between the cab and the bed on the left and right corners to make sure the gap is the same. My bed was cocked causing my measurements to be off.
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
