Old 05-07-2015, 08:16 AM   #26
Bullockchevy
Re: Front Disc's Rubbing on Lower A-Arm
Hey guy, old thread I know but I thought I would mention I have the same issue. Unfortunately for me I rushed putting the truck back together and didn't realize the rubbing issue until I cut a 1/4" 45º chamfer into the back side of my rotors...
If anybodies still watching this thread I can get some pictures of my damage to post. I was thinking maybe I needed to change to tubular a-arms or something.
Trent
1969 Short Bed Step Side
http://thebullocksolution.com/69-chevy-c10-the-history/
Bullockchevy is offline   Reply With Quote
Old 05-17-2015, 08:04 PM   #27
67 Burb
67 Burb's Avatar
I am very interested in this, as I just received my CPP disk brake kit for the Burb and plan on installing the kit soon. In the photos of steveb64's installation, it looks like he had used the existing lower ball joints (which look quite short). Is this the problem? I got the complete kit with new ball joints, tie rods,etc. So I hope that with the new ball joints, I won't have this problem. I also got dust plates with my kit.
Will report on my installation.
Bob
1967 2wd Burb, 350/TH350, 3.73 posi
67 Burb is offline   Reply With Quote
Old 05-17-2015, 09:34 PM   #28
four door
CPP offers a 73-87 ball joint upgrade. If you end up with 73-87 ball joints and a spindle meant for 63-66 ball joints the spindle will sit way too far down on the ball joint - the result is the disc rubbing on the lower A-arm.
four door is offline   Reply With Quote
Old 05-17-2015, 10:40 PM   #29
67 Burb
67 Burb's Avatar
I got the complete kit, so I hope that the spindles and ball joints work together. (Keeping my fingers crossed.)
I am also wondering what caused steveb64's rotors seem to go too far onto the spindle.
Bob
Old 05-18-2015, 09:11 AM   #30
Bullockchevy
Here is the picture of mine, it was using brand new MOOG brand ball joints for upper and lower. Also surprised at how quick everything got covered in rust so when I tear it back down to trim the lowers, I need to get it painted or powder coated.
Old 06-01-2015, 10:59 AM   #31
67 Burb
67 Burb's Avatar
Here's the clearance between my disc and the lower control arm using the kit from CPP.
Bob
Old 07-27-2015, 06:54 PM   #32
northern 85
northern 85's Avatar
Im having the same issue on a 66 with cpp modulars the rotor is rubbing the a arm i used new moog balljoints for the 66 a arms. Are there different balljoints to gain clearance?? Looks like i would have to grind way to much off.Thanks pics will follow.
northern 85 is offline   Reply With Quote
Old 07-27-2015, 07:10 PM   #33
northern 85
Old 07-27-2015, 07:30 PM   #34
northern 85
I bought new moog joints for the 66 arms and they still rub????
Old 07-28-2015, 10:43 AM   #35
chevy_mike
Never Ending Projects
chevy_mike's Avatar
It almost looks like you have too much positive camber (top stick out more than bottom) which will tilt the bottom edge of the rotor into the arm. If you can set your lower arms at ride height and put a 90* square on the ground and up to the face of the rotor, it should be flush or slight gap at the top of the rotor to the square. If you have a gap at the bottom, you need to remove shims from the upper arm.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-28-2015, 08:15 PM   #36
northern 85
Thanks you are right,i had noticed this was way off when i first installed the spindles and 2 inch drop coils, top of the tires were way out (more on pass than driverside) so i took all removable shims out,the only one left is cone shaped washer.I just checked with the square and i still have a quarter inch gap on the bottom of the rotor. Am i missing something else?? Thanks for the help.
Old 07-28-2015, 09:40 PM   #37
northern 85
Old 07-29-2015, 12:22 PM   #38
chevy_mike
chevy_mike's Avatar
Wow, that is a lot to pull in. Did you ever pull off the upper A arms? I did on my '68 and put them back on the wrong sides, which caused problems. Something somewhere is definitely off as with no shims, you should have a gap at the top of the square to the rotor. Was the truck ever in an accident where it could have twisted the frame rails? Definitely weird.
Old 07-29-2015, 12:45 PM   #39
northern 85
Nope never took them off the truck, can't see any damage to the frame . It drove nice before I pulled it apart. Time to go deeper I guess.
