Old 03-07-2015, 09:45 PM   #26
jjzepplin
jjzepplin's Avatar
Re: Project: ____________________________
Nice!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is online now   Reply With Quote
Old 03-07-2015, 09:49 PM   #27
Devillusion
Devillusion's Avatar
I have a couple spare frames as well.......so current plan is to bring one of them home, get the 52/63 swap completed, get the rear shackle flip installed, diffs in, perches in the rear to be welded in when all together and weight is on them, get the cummins and driveline installed, frame shortened........then decide what will happen with the body from there.
There is the option of combining my CCSB projects and maybe the possability of putting my 2wd cab on that chassis and keeping the blue one for my trail rig. Can only keep so many...so...will see what happens. This way I'm not tearing down a perfectly good truck and wasting a bunch of build time and redundant efforts.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s
1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater
1963 C10 reg cab long box
1970 Chevelle
1968 Biscayne 2dr post
"...there is no excuse for what I am about to do, but dangit....it's gonna be fun!"
Devillusion is offline   Reply With Quote
Old 03-10-2015, 02:45 PM   #28
Hankster
Hankster's Avatar
I'll be following this one as well as your others.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 03-11-2015, 12:50 PM   #29
68Timber
I know the pieces fit
68Timber's Avatar
Sub'd
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-07-2015, 01:44 AM   #30
Devillusion
Nothing much to report unfortunately. Still collecting parts...and selling what I don't need. Traded the box to a buddy for some parts.
1970 Chevelle
Old 04-09-2015, 04:12 PM   #31
Hankster
Hankster's Avatar
Sweet!
Current Build
Old 04-15-2015, 08:59 PM   #32
Devillusion
Making some additional progress on the parts collection....no real work done yet. Still have some more stuff to order up/make before even thinking about starting. Going to look at a possible cab candidate and might build from scratch now and keep my blue crew as a trail rig...just toss on the swampers, small lift, and go for now.
Parts include: on board air compressor (direct bolt on), 1" body lift, NV4500 GM/Dodge hybrid with 205 adapter (still have to locate a 6 bolt round pattern 205 GM case), poly body mount kit, 31 gallon fuel tank, sender, straps, KILLER deal on actual cummins complete gasket set ($170US/set), and some odds n ends.
Also looking at using a guy I found on one of the forums for my crossmember, and frame boxing pieces. Can't barely make them for what he is charging. Also going to be working with him I hope in the near future on designing some rear crew/1ton frame boxing plates for the rear. Come fabricated with dimple die holes n all. Crazy clean work too....will keep you posted as things progress and confirmation is had that things are a go.
Anyway, on with the show.
1970 Chevelle
Old 04-20-2015, 07:28 PM   #33
Hankster
Hankster's Avatar
You have quite the parts pile there!
Current Build
Old 04-23-2015, 07:21 PM   #34
Devillusion
Ya....been a while collecting lol
Only have a few things left to collect, one being a 6 bolt round pattern NP205 with a fixed rear yoke and 32 splines. But think I found a couple this week, just waiting to hear back. They were only made from 85 to 91 behind the 465 and T400 transmissions and 91 was a VSS version. So not easy to find in most cases.
1970 Chevelle
Old 04-23-2015, 07:40 PM   #35
Hankster
Hankster's Avatar
Hmm, well I amnot really a 4wd guy some I'm sure I will learn some stuff from you!
Current Build
Old 04-23-2015, 11:36 PM   #36
joe231
joe231's Avatar
In 1991 the NP205 with VSS came behind a 4L80E, that is another thing that makes the NP205 and the adapter highly desirable. I just sold my 1991 crew with that setup. Now I need to find another for a 6.0/4L80E swap into a 4x4 CCSB
I have around pattern, non-VSS NP205 that I HOPE I can convert to VSS, then I'll only need the adapter. Do you know if the TH400 to round pattern NP205 is the same?
Edit: I just found out the TH400 adapter is different but Northwest Fab sells an adapter to make it work with the 4L80E. They also sell a VSS conversion kit for the NP205
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 04-24-2015, 08:19 PM   #37
Devillusion
Sorry Joe....just seen this now. lol. Bit late I guess.....You already know hhahaa.
I am buying another dually 4x4 crew cab (chassis only) and it has the case I need, going to part out the rest or maybe even commandeer the frame for my cummins build and save some time.
On another note I got a smoking deal on a set of 2005 RAM leather crew cab seats that I am going to put in. Looks like it will be a super easy conversion and will be nice to have a flip up rear seat too. They are even grey, so worst case scenario I will buy a set of KatSkins later on and delete the ram logo....think I am going to get a skull with horns made in place of it...just cause. lmao.
Will post up some pics later on when I get them cleaned up. They are filthy right now.
1970 Chevelle
Old 04-25-2015, 02:08 AM   #38
joe231
joe231's Avatar
Lol
No worries
I really like the skull with horns idea!!
CHEVY ONLY
Old 04-25-2015, 02:59 AM   #39
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
You've got a lot of good pieces to build a sweet rig. Very nice! That gasket set was a steal at $170 too.
Ryan
1969 Chevy milk truck
Old 04-28-2015, 08:14 PM   #40
COS399
COS399's Avatar
Just found this one but I'm all in.
1987 GMC R2500 SC 454 T400
1988 Chevy R30 CC DRW 12 valve Cummins NV4500 GearVendors
COS399 is offline   Reply With Quote
Old 05-04-2015, 10:50 PM   #41
brimc
brimc's Avatar
Awesome Build. I'm following along for sure.
BRIAN
1986 Chevrolet K20 Silverado 12 Valve CUMMINS P Pumped Intercooled/Getrag360/Divorced NP205/10B/14BFF Detroit Locker - DD Canadian Winter Beater.
My Chevrolet CUMMINS Build http://67-72chevytrucks.com/vboard/s...d.php?t=585509
brimc is offline   Reply With Quote
Old 05-28-2015, 12:29 AM   #42
Devillusion
yes, absolutely. Reason I bought 2...hahaaha. Figured it was a no brainer. Up here the head gasket alone is well over $200 my cost.
1970 Chevelle
Old 05-28-2015, 12:48 AM   #43
Devillusion
more parts collecting......
D60 spring plates, 14FF spring plates, frame plates, D60 bushing kits, spring perches, hangar bearing drop kit, 4" front lift springs and greaseable bushings, 63" rear springs with greaseable bushings, shock relocation tabs, rear shackle flip, twin stick kit for the 205 tcase swap, and just got my adapter for between the case/trans today from NorthWest Fab as well.
Cross over steering should be here Friday.....then just waiting to order my crossmember and frame boxing kit from Rob Bonney Fabrication. Absolutely gorgeous looking stuff if anyone is looking. Will do consistant updates when stuff arrives and the build actually starts. REALLY looking forward to getting this stuff from Rob....spoke with him on the phone a week or two ago...super nice guy, and on the ball....knows his stuff for sure. Can't wait!!
1970 Chevelle
Old 05-28-2015, 05:02 PM   #44
hick
What kind of hassle did the border give you bringing those panels up? I doubt theres not much they can do cause its not a cab with a vin number.
They make you pay duties or anything?
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims.
hick is offline   Reply With Quote
Old 06-01-2015, 04:04 AM   #45
Devillusion
No hassles what so ever......classified as parts. I think they charged me taxes..bout it if I remember right.
1970 Chevelle
Old 06-01-2015, 01:50 PM   #46
hick
I visit Nevada/Arizona quite a bit because the old man lives there. Ive been debating buying a few trucks and just dismantling them and bringing them home to sell. Little easier then whole trucks I think
Old 10-09-2015, 03:38 AM   #47
Devillusion
Been on a roll this week getting stuff done. Managed to get the frame shortened, 64" leaf swap done, shackle flip installed, Blazer 40 gal tank along with brackets, 2003 14FF with factory disc brakes, built some adjustable perches as well, along with new greaseable poly bushings, upper spring plates, new U bolts, and some odds n ends.
Next is to build a reciever hitch, shock brackets, and then get the rear portion of the frame blasted then paint/install everything.
Front hangers were placed 4-5/8" center to center from rear cab mount rivet to first upper bolt hole in front hanger. This left the center line of the differential in stock location and allowed room to bolt hanger in place without major issues. Then mounted rear shackle flip bracket 63-1/16 center to center fixed hanger locations. This left a 10 degree rearward angle under load on the rear shackle giving the best ride possible ride and allowing the springs to do the work, not the shocks. Shocks will be mounted as far apart as possible and mounted at a 20 degree angle.
[/IMG]
1970 Chevelle
Old 10-10-2015, 08:29 AM   #48
Wrecked1982
Wrecked1982's Avatar
nice work
1981 c30 dually, 350 sm465 ex tow truck now yard mule
1985 k35 dually, 454 th400 np205
1985 D30 cucv M1008, 6.2 th400 np208
1999 toyota tacoma, lifted 6'' 31'' tires
2003 toyota echo, reliable and damn cheap on ga
z
Wrecked1982 is offline   Reply With Quote
Old 10-10-2015, 09:41 AM   #49
y5mgisi
Second Chance Program
y5mgisi's Avatar
Nice dude!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-17-2015, 03:44 AM   #50
Devillusion
Got some mock up pieces completed, and pics taken. Fabricated some load leveller bag brackets and frame reinforcement plates, receiver hitch, shackle flip, 2005 rear disc 14ff, 63" springs, blazer tank..etc. I tied in the frame plates to the hitch front mounts as they were right there anyway, and what can it hurt. Still have to make the shock mount in front of the axle and tie it into the outer plates as well.
1970 Chevelle
