60-66 Nut
Re: Tremec in a 66 c10
I believe the cast fork will work in the 621 bellhousing, but I can't say for certain having not done that. If it were mine, I would use the stamped fork that would typically be used with the bellhousing and just shorten the pushrod between the bellcrank and the fork. you will also need a different end on the pushrod to mate up with the stamped fork.
#2 | |
60-66 Nut
I don't have a particular stamped fork in mind. I would have to do a little research before selecting one that is close to the same ratio as the cast fork. I do not have a truck that is setup with anything other than a stock bellhousing and trans.
