Old 06-02-2015, 11:33 PM   #1
old Chevy guy
old Chevy guy's Avatar
spark plug gap with HEI dizzy
If I have an HEI distributer should I have a bigger gap in the plugs than if I had points? I think my newer trucks with HEI plugs were pre gapped at something like 45 but if I remember right old point stuff was like 24. My trucks had an HEI for a while but as I was about to put in the plugs today it occurred to me that I had never thought about that before and just put in what I was given. If it should be a bigger gap what should that be? Can anybody tell what the difference would be? thinking it will be a hotter spark jumping a larger gap but....?
old Chevy guy is offline   Reply With Quote
Old 06-02-2015, 11:35 PM   #2
enaberif
Re: spark plug gap with HEI dizzy
0.045 is a good setting for hei
enaberif is offline   Reply With Quote
Old 06-03-2015, 12:18 AM   #3
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
If I recall a pinch more than what it would otherwise be for your points.
Now if I could just remember what my timing should be.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 06-03-2015, 01:08 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup -- .035 for points, .045 for HEI.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 06-03-2015, 04:01 AM   #5
EvanR
EvanR's Avatar
As with everything its about the sweet spot. The benefits to bigger gap is that it ignites the fuel quicker, resulting in faster, more reliable starting and a more powerful burn. but too big and you can burn up your coil or even cause a misfire. A standered HEI is 35,000 volts and should be set at .45 spark plug gap. Whats the output on your coil?
If it works, don't fix it.
EvanR is offline   Reply With Quote
Old 06-03-2015, 07:40 AM   #6
old Chevy guy
Should just be stock standard. It just the factory coil in the top of the cap.
Old 06-03-2015, 09:51 AM   #7
Fitz
The instructions from GM for my crate motor with that cap specify 0.038. for plug gap.
Fitz is offline   Reply With Quote
Old 06-03-2015, 10:57 AM   #8
LPoole
LPoole's Avatar
yeah .038 is what O'reileys quoted me when I put in a set of AC Delco plugs just a few weeks back.
Better to remain silent and be thought a fool than to open your mouth and remove all doubt. - Mark Twain
LPoole is offline   Reply With Quote
Old 06-03-2015, 01:45 PM   #9
'68OrangeSunshine
'68OrangeSunshine's Avatar
Don't assume any plugs are ''Pre-Gapped''. A good thump on the loading dock, and a gross of plugs are all out a couple thousandths.
Old 06-03-2015, 03:45 PM   #10
GRX
GRX's Avatar
^^ x2. Never had a set where they were gapped all the same out of the box.
GRX is offline   Reply With Quote
Old 06-03-2015, 05:36 PM   #11
VWNate1
VWNate1's Avatar
Post Re: spark plug gap with HEI dizzy
FWIW ;
Back when HEI was a new thing in 1975 , GM told us to use .060" .
It turned out this made the engine run GREAT but chewed up rotors and caps pretty quickly so the decided .045" was a good middle ground .
My 1969 C/10's 250 CID i6 burns a quart of oil every 150 miles and fouls plugs to missing by 200 miles so I added an stock HEI and began experimenting with plug gaps ~ I now run .070" and have no smoke , little burned oil smell and don't foul the plugs any more .
So far the Junk Yard 1977 HEI has help up just fine , over 20,000 daily driven miles sans problems .
Even breaker points ignitions should be gapped to .035" , you'll feel the power .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 06-03-2015, 06:49 PM   #12
71K20chevy
71K20chevy's Avatar
I'm running .045 on mine.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 06-03-2015, 07:18 PM   #13
old Chevy guy
I just set them at 45 and put them in so I hope that will be fine. I going to post another thread about what wires do I need to get to be long enough as in application not brand . I cant go to the auto zone and buy wires for my 71truck with HEI cause it didn't come with that.
Old 06-03-2015, 07:39 PM   #14
GRX
GRX's Avatar
Wires for a '75 should work. First year HEI was standard equipment.
Old 06-03-2015, 11:05 PM   #15
flashed
This is very useful info guys ,thanks as I needed to ask that very question.
flashed is offline   Reply With Quote
Old 06-04-2015, 08:36 AM   #16
old Chevy guy
For the record the question asked and answered in another thread I posted is 75-78 corvette wires, HEI and long enough to go around the back and under the manifold like factory original .
Old 06-05-2015, 01:11 AM   #17
'68OrangeSunshine
I usually get the Accel 8mm wire in trim-to-fit.
