Old 06-03-2015, 12:00 PM   #1
t76turbo
Re: Accuair Install with pictures.
Originally Posted by jadedbird View Post
So when is it necessary to run 2 batteries?
He is probably running a lot of high draw stereo equipment or other high draw electronics.
Otherwise I don't see a reason to run dual batteries on a gas vehicle(diesel requires it for starter).
I ran 2 batteries with battery isolator in a 88 suburban I had. But I had a few very high draw amps and 4 12inch subs in a competition level system.
1970 Shortbed 2wd C-10
t76turbo is offline   Reply With Quote
Old 06-03-2015, 12:59 PM   #2
1moretoy
I just figured with two compressors and a stero system it wouldn't hurt. Plus the batteries are a little smaller then usual so I could tuck them up out of site. Might not be needed but it definitely doesn't hurt and the investment wasn't that much more. If I'm parked with the radio on they will last longer before they die.
1moretoy is offline   Reply With Quote
