Old 06-01-2015, 04:40 PM   #176
BigJohn145
Re: 1971 GMC SWB "No Direction" LS build
Great looking wheels!!!!!
BigJohn145 is offline   Reply With Quote
Old 06-01-2015, 09:04 PM   #177
GAc10boy
GAc10boy's Avatar
Thank you! They're fairly common on these trucks but I couldn't pass them up. Should hold me over until I can get my dream wheels.
I was surprised to learn they're made in the USA. That's pretty cool!
- Robbie
UNITED BY TRUCKS - classic truck video content
YouTube: www.youtube.com/c/unitedbytrucks
Instagram: @united_by_trucks
Paw Paw '68 508 Dark Blue Custom C10
Teddy '68 GMC SWB 503 Light Green LS Build
Mississippi Mud '75 Skyline Blue Patina SBC Build
GAc10boy is offline   Reply With Quote
Old 06-01-2015, 10:58 PM   #178
flashed
Robbie ,Im in Kokomo Indiana until tomorrow morning ,having a blast .We have seen several old trucks along the way that looked abandoned but in pretty nice condition ,wish we could have stopped and checked them out.We will be in Michigan tomorrow to go to the Henry Ford Museum and then to Frankenmouth for the night. Chuck has a lot planned for us to see.
flashed is offline   Reply With Quote
Old 06-02-2015, 09:19 AM   #179
GAc10boy
GAc10boy's Avatar
That's so cool! I can't wait to hear all about it when you get back. Ya'll stay safe and have fun!
- Robbie
Old 06-02-2015, 06:20 PM   #180
flashed
Robbie ,we are now in Canton/Ann Arbor Michigan and will go to the Henry Ford Museum tomorrow and we also hope to meet up with some friends up here as well.We finally got to drop the top on the Malibu today ,perfect day and place for cruisin. I never knew how nice Indiana and Michigan were before .The backroads Chuck picked out for us are great .
Old 06-03-2015, 09:35 AM   #181
GAc10boy
GAc10boy's Avatar
I actually spent some time up in that region one summer a few years back. We drove up to Indianapolis for a wedding then, on a whim, decided to drive up to Lake Michigan. A lot of big corn fields and wide open spaces on that route. Was really nice!
- Robbie
Old 06-03-2015, 09:49 AM   #182
GAc10boy
GAc10boy's Avatar
So I know this issue has been beat to death on this forum but I tried to fit my Boss 338 20x8.5 with O-Ring caps (newer version) on the front of my 1.25" rotors and, exactly what everybody on this forum would expect, it needs some very minor grinding of the rotor hub. And likely some minor dimpling of the dust cap.
Not mad about it since I knew about this issue when I bought them. They actually ALMOST seat properly but not quite. Out comes the grinder!
I've also been getting in a host of parts from Summit. I'm planning to re-run my fuel system this weekend and maybe even get started on the drop. Details below on it:
- 3" Belltech drop spindles
- 1" CPP coil
- 3" CPP coil in the rear
- 2" Way2lo2 blocks
- CPP adjustable trac bar
- CPP shock relocators
- KYB shocks
- Robbie
Old 06-03-2015, 01:05 PM   #183
Advanced Design
Advanced Design's Avatar
Glad you can make the wheels fit. They do look good. Looking forward to drop updates. Good list of parts.
Advanced Design is offline   Reply With Quote
Old 06-04-2015, 09:09 AM   #184
GAc10boy
GAc10boy's Avatar
Thanks, AD!
- Robbie
Old 06-05-2015, 11:37 AM   #185
lowlyfec10
I'm really reconsidering just keeping my stock tank now. lol i did just order an assortment of russell fittings needed. any suggestions for a place to clean and coat the tank? mine has a bunch of surface rust n **** inside -_-
lowlyfec10 is offline   Reply With Quote
Old 06-05-2015, 12:09 PM   #186
Xeen
Xeen's Avatar
There are probably more that a few places around town that can hot tank it for you and as long as there isn't any bad rust on the inside you don't even need to coat it after.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 06-05-2015, 12:10 PM   #187
GAc10boy
GAc10boy's Avatar
I had my last one boiled, cleaned, and sealed with an internal protective coating at Marietta Radiator not far from the Marietta Square. I think it was $175 but they painted it black and everything.
Thankfully, the one in my current truck is clean as a whistle.
- Robbie
Old 06-05-2015, 12:10 PM   #188
lowlyfec10
havent looked lately. wasnt like rotted...just surface type rust from sitting and being empty...def some debris floatin around in the bottom. ill search around.
Old 06-05-2015, 01:45 PM   #189
Number98
Prestige Worldwide
Number98's Avatar
Awesome score on the wheels Robbie!! I cant wait to get over your way here soon and help get this girls altitude adjusted....
Number98 is offline   Reply With Quote
Old 06-05-2015, 01:47 PM   #190
Number98
Prestige Worldwide
Number98's Avatar
If your tank is bad let me know, I have two that are both really clean and you are welcome to one if you can use it since I am never going to do anything with them.
Old 06-05-2015, 09:36 PM   #191
GAc10boy
GAc10boy's Avatar
Thanks, Jason! I'm looking forward to it, too. Planning to get a few things started tomorrow.
- Robbie
Old 06-05-2015, 10:01 PM   #192
flashed
PICTURES ,PICTURES ,PICTURES or it didnt happen.
Old 06-06-2015, 09:52 PM   #193
GAc10boy
GAc10boy's Avatar
Well since you asked.....
It was a super productive day but once I got out to the garage and started looking at everything I'd bought for the fuel system and how I was going to make it work, I decided I needed to try something different. Basically, the whole system was contingent upon me having the correct adapter fitting for the hard line out of the tank to a -6 AN end. Well, the line out of my tank was 5/16 and I had bought a 3/8 adapter fitting. Also, the fuel feed line from the carb I was going to use wasn't going to be delivered until the 21st. All that said, I grabbed a piece of paper and my laptop and figured out an even better solution than all the PTFE line and super expensive fittings. Here's what I ended up going with:
3/8 aluminum hard line
Russell banjo carb to -6 AN fitting
Various Russell 3/8 to -6 AN adapters
Russell Pro Classic II braided hose
Russell fuel filter
Holley Red pump
Earl's 5/16 hard line adapter to -6 AN fitting
So, once I got that I started constructing a few hoses and connected the banjo fitting to the carb; fitting to the hard line out of the tank; and fittings to fuel pump. I'm one hose end short and am likely going to run another fuel filter before the carb but it's progress. Need to get a tube bender, too.
Since flashed asked, here's a few pics. I also got my PCV valve and lug nuts while I was at Summit.
Anyway, pics....
- Robbie
Old 06-06-2015, 10:21 PM   #194
flashed
Is that all ? LOL
Old 06-06-2015, 10:43 PM   #195
GAc10boy
GAc10boy's Avatar
Is that all ? LOL
John, you are killing me! Lol
I was a one man team, didn't even get out to the garage until 11 am, cleaned up the garage, then had a 3 hour roundtrip to Summit after I spent about an hour researching new parts and finding receipts for the current stuff. Considering all that, it was a productive day.
It's amazing how much time I spend looking at stuff trying to figure out the best possible route/way to do it.
- Robbie
Old 06-06-2015, 10:48 PM   #196
Advanced Design
Great ideas on the plumbing. Yep, it always seems to take way more time figuring out parts and sources than putting something together. A good day.
Old 06-06-2015, 10:52 PM   #197
flashed
Its easy for me to give you a hard time since mine is done (sorta) ,buts its all in good fun .Im just a little bored right now sitting in a hotel room far from home busting your chops but you are actually accomplishing something with your truck and 2 of mine are at the bodyshop .The 1 ton is just waiting for something to happen and the red truck I hope is getting dual electric fans installed .At least you are working on your own truck as I hire someone to do mine while Im out playing .I look forward to seeing you and your truck cruising around .
Old 06-07-2015, 11:40 AM   #198
GAc10boy
GAc10boy's Avatar
It's all good, John. I know you're just giving me a hard time. I've had a ton of help along the way and still need a ton but I'm trying to do what I can and learn as much as possible along the way. It's a fun process and I'm thankful I have this board and folks like you and Number98, among many others, who are willing to answer my ridiculous texts/messages at times.
Can't wait to hear all about your trip!
- Robbie
Old 06-10-2015, 04:18 PM   #199
GAc10boy
GAc10boy's Avatar
New black anodized valve cover breather to complete the PCV system.
- Robbie
Old 06-13-2015, 09:10 PM   #200
GAc10boy
GAc10boy's Avatar
Made another trip to Summit, got more of the fuel system put together and Number98 came by and helped me knock out the front drop (3" spindles, 1" coil). Next up finishing up the fuel system, dropping the rear, and getting the exhaust put together. Another set of TBSS manifolds (w/collectors) are on the way as well. Should be here next week.
No pics since I'm getting new rotors and don't have the wheels on yet. Not a bad Saturday at all. Also, goes to show you how awesome this board and it's members are. Thanks again, Number98.
- Robbie
