Old 06-03-2015, 02:44 PM   #1
kelsfine69
18 Till I Die
kelsfine69's Avatar
1973 with 6 bolt lugs but not 4x4?
Not mine. I thought 72 was the first year for 5 bolt disk brakes? This is a 73 with 6 bolt rallys on it and that would indicate front drum brakes in a 2wd?
http://seattle.craigslist.org/est/cto/5055156404.html
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 06-03-2015, 03:25 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: 1973 with 6 bolt lugs but not 4x4?
My guess it was a conversion.
Must have had a 6-lug rearend they wanted to use.
6-lug aftermarket rotors and drop spindles.
Was this an 8-lug truck before???
I don't know these VIN numbers,...
Keith
Convert to disc brakes.
Old 06-03-2015, 03:38 PM   #3
93M6Formula
Definitely not a factory thing. i'm guessing he just bought a set of 5 to 6 lug wheel adapters. That would make the most sense.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4
1988 GTA Trans AM 305 TPI 700R4
1993 Formula Firebird LT1 T56
1995 GMC K2500 ECLB 6.5L 4L80E
1996 GMC K3500 CCLB LB7 6L90
93M6Formula is offline   Reply With Quote
Old 06-03-2015, 04:47 PM   #4
piecesparts
Parts and more parts
piecesparts's Avatar
In those days, you could order a truck however you wanted it. Many railroad and forestry trucks had heavier duty axles and spring sets on them.
Frank
Old 06-03-2015, 05:35 PM   #5
Joesjunk
Joesjunk's Avatar
I saw that truck on eBay last week. I noticed the 6 lug wheels right away. That truck was a 1/2 ton from the factory and should be 5 lug. Someone should email him and ask what's up with the 6 lug wheels.
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 06-03-2015, 07:43 PM   #6
lolife99
lolife99's Avatar
5-6 lug adapters are the most unsafe adapter on the market.
I hope this truck was built around a 73-87 4x4 rearend and conversion 2wd 6-lug rotors.
Keith
Old 06-04-2015, 09:05 AM   #7
D13
D13's Avatar
In 69-72 the Heavy Half could be ordered as a 6 lug in 2wd. I don't think this carried over into the 73. My guess is someone found a 6 bolt replacment axle and used the 6 bolt rotors in the front - pretty cheap swap. Unlikely it was a 4wd that was converted with a front crossmember swap. Since 73 wil bolt into 72 maybe they had a 72 6 bolt front laying around...
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 06-04-2015, 09:08 AM   #8
lolife99
lolife99's Avatar
I have never seen a 6-lug 2wd 71-72 truck.
Any more info on this would be appreciated.
Keith
Old 06-04-2015, 09:51 AM   #9
tlawre87
tlawre87's Avatar
Here is the VIN:
T- GMC
C-Conventional Cab
Z- 454 Engine
1-1/2 Ton
4- Cab and Box
3-Model year 73
Z-Built in Fremont
503807 - Sequence Number
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 06-04-2015, 10:08 AM   #10
65standard
65standard's Avatar
You could get the 454 in a C10? I thought a C20 or bigger was required to order a 454.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 06-04-2015, 01:41 PM   #11
93M6Formula
You could order them in the higher end models like the Cheyenne Super/Sierra Grande and the BIG 10 trucks as well. K10 trucks couldn't get a BBC as far as I know. Some of the special edition sport trucks could be optioned with it also.
Old 06-04-2015, 02:23 PM   #12
greg64
greg64's Avatar
Yup, and for 1976, the C10 with 454 was the fastest accelerator on the road. Beats the corvette. There was a road & track or car and driver article testing it at the time. Everything non-truck was wiped out by smog controls.
Greg
64 GMC Suburban - 283, NV3500, 14 bolt
77 C10 swb - 292, SM465, 12 bolt
greg64 is offline   Reply With Quote
Old 06-09-2015, 06:31 AM   #13
Joesjunk
Joesjunk's Avatar
I asked the owner about the 6 lug wheels and this was his response,
You are correct. When the lower kit was installed the current rally wheels were found and wanted to be used then because of looks and better width. When the front end was replaced/rebuilt including brakes the front rotors were swapped with new 6 lug and the axle shafts were replaced with new wheel bearings. There are no adaptors on the truck.
Old 06-09-2015, 07:29 AM   #14
lolife99
lolife99's Avatar
Thanks for clearing up the mystery.
Seems like a lot of expense to fit a set of 6-lug rally wheels that are the same width as a set of 5-lug rally wheels.
But that's what makes everyone different.
Keith
Old 06-09-2015, 07:35 AM   #15
Joesjunk
Joesjunk's Avatar
That was my thought to Keith, they must have really wanted the 6 lug. And with a claimed 32k miles the front end shouldn't have needed a complete rebuild? Whatever the story is with it, it's a nice truck
Old 06-10-2015, 10:24 AM   #16
USSkoval
While that is sorta true, you couldn't just "order whatever you wanted". There were never any 6-lug trucks in '73 and up.
454 was available in a C10 through '79 or '80. Not available in a K10 or even K20 though. Or even the early K30's actually.
-Andy
'77 K5 Blazer
'78 K10 Shortbed
'78 C20 Suburban
'79 K30 Crew Cab Dually
'84 C10 Short Stepside
'88 K20 Suburban
USSkoval is offline   Reply With Quote
Old 06-10-2015, 09:42 PM   #17
I figured exactly what the seller said. Not necessarily that much extra expense and I think it gives super cool factor, as a truck. What a sharp truck, too!
There was never a heavy half 6-lug 2wd offered. Back in the day when you could these trucks any way you wanted, you couldn't order that. It had to be something used on some other production model. They didn't custom make parts for anyone.
