Old 05-30-2015, 05:14 PM   #1
yote1234
yote1234's Avatar
factory look black bed wood results
for those who want the factory look bed wood in black, I found this. hope it helps .
watch this.
http://www.woodworkerssource.com/blo...king-projects/
1971 K5 CST Blazer
1965 Chevelle Malibu 283 (sadly sold)
1968 Camaro 327
1968 Honda mini-trail z50a #377
1966 uh 1-D Huey
yote1234 is offline   Reply With Quote
Old 05-30-2015, 05:24 PM   #2
Re: factory look black bed wood results
That looks kool. I would have never thought of that.
Old 05-30-2015, 06:15 PM   #3
yote1234
yote1234's Avatar
yea. im investigating the best way to do it. lots of reading up on this.
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 05-30-2015, 06:47 PM   #4
Captmatt
Finished mine a few weeks ago. Used ebony stain and spar urethane in satin finish. Four tries before I got the look that I wanted. Something that I did not think of, black shows EVERYTHING. Every speck of dust and every little imperfection in the finish is magnified . If possible do the urethane in a spray booth. All in all I'm happy with the way it looks.
Captmatt is offline   Reply With Quote
Old 05-30-2015, 06:54 PM   #5
yote1234
yote1234's Avatar
That's nice!!!!
1971 K5 CST Blazer
1968 Camaro 327
1966 uh 1-D Huey
Old 05-30-2015, 09:22 PM   #6
Indian113
Indian113's Avatar
Captmat, That looks Awesome! I'm wanting to do that to our 64
Indian113 is offline   Reply With Quote
Old 05-30-2015, 09:31 PM   #7
Uptown83
Awesome plan to do this to my 66.
White truck with black wood? I think it would look good.
Uptown83 is offline   Reply With Quote
Old 06-02-2015, 07:23 AM   #8
theastronaut
theastronaut's Avatar
That looks really good. I'll have to remember that technique for when I do the bed floor in my '66.
I used oak and painted it with reduced exterior latex on the '65 I restored. Had a similar look.
theastronaut is offline   Reply With Quote
Old 06-02-2015, 09:50 AM   #9
Metalaroundstone
I noticed another option for black wood on the Mar K site where they tested different finishes. http://www.mar-k.com/final_summary.aspx and 2010 update at http://www.mar-k.com/june_2010_update.aspx
After years of testing they found that the following finish was the most durable compared to clear finishes. They did not compare different black finishes.
Oak boards, coated with three brushed coats of POR-15 Rust Preventative Paint three hours apart, then three coats brushed Behr best quality black exterior latex enamel, three hours apart.
Metalaroundstone is offline   Reply With Quote
Old 06-02-2015, 08:52 PM   #10
Monte's62
Anything with POR-15 on it should last forever. I think I still have some on me from 2013. Great info guys.
Monte's62 is offline   Reply With Quote
Old 06-03-2015, 01:11 PM   #11
ACK
ACK's Avatar
Would've been great if they had included boiled linseed oil with lamp black in the test to see how the original bed board coating compared to the rest of the line up.
My truck ain't dead, it just smells funny.
ACK is offline   Reply With Quote
Old 06-03-2015, 01:22 PM   #12
TJ's Chevy
TJ's Chevy's Avatar
Looks nice! Great ideas.
Old 06-03-2015, 01:56 PM   #13
Metalaroundstone
That would have been a great idea. I wonder if anybody has redone their truck bed using the original formula and has left it out in the elements. I am also curious to know how the original finish holds up to the weather.
Old 06-04-2015, 01:04 PM   #14
cg285
i did mine with southern yellow pine, linseed oil, lamp black and a binder. looks just like it did when you could still buy the bed boards from gm. been on 5 years and looks the same - however it doesn't stay out side all the time
my brother, the wood butcher, did his the same way but used oak. didn't come out black
cg285 is offline   Reply With Quote
Old 06-04-2015, 01:13 PM   #15
ACK
ACK's Avatar
What binder did you use? Do you recall the ratio of lamp black to linseed oil? I have the oil and the lamp black, but no recipe to create the concoction.
Old 06-04-2015, 01:30 PM   #16
cg285
a lot of beers consumed the last 5 years. best i remember i winged it on the carbon black. i may have gotten a recommendation from where i got the binder as to how much binder. (i don't think the black/linseed ratio is overly critical)
took a lot of research to find a place that sold the binder:
guerrapaint.com
Old 06-04-2015, 01:37 PM   #17
cg285
i brushed it on and it flowed out with no brush strokes. took awhile to completely dry.
Old 06-04-2015, 01:43 PM   #18
cg285
as far as holding up - i date to back when you could still buy the boards from gm and i bought a set for a 64 that got used hard and put away wet. had the truck over 10years and best i can recall the wood was still in excellent shape when i gave it to my kid...
i have a 65 that has the original bed wood and it is in like new shape. however it had a rare (pullman) camper top on it since new.
Old 06-04-2015, 03:46 PM   #19
oem4me
Sorry for adding to the going off topic direction here, but I'm going out on a limb and saying that our trucks had PAINT on the factory bedwood boards. Linseed oil and lampblack may have been used for older generation trucks, but i think ours had paint. I say this because I've had a little experience with both oiled finishes and paints, and my survivors show a lot more like regular paint than any pigmented oil concoction.
Old 06-04-2015, 04:44 PM   #20
cg285
pigment, base and binder = paint
