Old 06-04-2015, 10:03 PM   #1
CURSED GEARS
Cab corner floor extensions?
Greetings!
Got a question. Used the search button, didn't find anything. Anyway, I've put a new full floor in my 70 C10. The rear of the floor is square on both ends, but as you know, the cab corners are rounded. Is there inside panels that seals the cab? I imagine that will be quite the breeze in the winter time, as well as stuff falling through the floor.
Anybody know the answers? Haven't seen any thing like that in any of my catalogues.
CURSED GEARS is offline   Reply With Quote
Old 06-04-2015, 10:18 PM   #2
65standard
65standard's Avatar
Re: Cab corner floor extensions?
The very bottom of the cab corner squares off as it folds under and seal to the floor.
Tony Nicholas @ Midwest Metal Masters
1953 Chevy 3100 392 Hemi w/727 & 9” Ford
1985 Chevy C/10 6.0L 4L80 373 locker
65standard is offline   Reply With Quote
Old 06-04-2015, 10:22 PM   #3
CURSED GEARS
Well, Either I did something wrong, or the reproduction cab corners are off a bit. I'll look tomorrow. Thanks for the quick response.
Old 06-04-2015, 10:29 PM   #4
sduckworth13
sduckworth13's Avatar
What brand of cab corner did you get? Where did you buy it from?
Scott
sduckworth13 is offline   Reply With Quote
Old 06-05-2015, 05:33 AM   #5
CURSED GEARS
They are Woodall brand, and I got them from Southern Kentucky classics.
For the Pan and the cab corners to work as stated above, the floor would have had to be below the lower cab belt line. I measured another cab to see where the gas tank bolt holes were from the back of the cab, to the floor, and replicated it on my floor. I think the floor is where it needs to be.
Old 06-05-2015, 08:46 AM   #6
Nsanehotrodz
Nsanehotrodz's Avatar
The cab corner spot welds to the lower flange on the inner rocker. The floor drops off and does not touch the cab corner until it hits the very bottom flange.
www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
Old 06-05-2015, 02:20 PM   #7
CURSED GEARS
Thanks. Then I guess everything is where it should be.
