Old 06-05-2015, 03:40 PM   #1
osaltyone
osaltyone's Avatar
Accelerate and dies
I have this 49 with a 216, just replaced the fuel tank, lines, filter and a bunch of other stuff. It seems to idle great, but as soon as I touch the gas pedal it will die. When I first start it and have the choke all the way open I can hit the pedal no problem, but once the choke is off no dice. Any ideas? Accelerator plunger maybe? Carb was new a few years ago and truck hasn't been driven in 15-20yrs. It's been sitting in my in laws garage.
osaltyone is offline   Reply With Quote
Old 06-05-2015, 04:05 PM   #2
Old Crow
Old Crow's Avatar
Re: Accelerate and dies
Yup. accelerator pump or maybe just some crud in the carb.
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 06-05-2015, 05:17 PM   #3
OrrieG
OrrieG's Avatar
Yes, when I ran the 1bbl carbs, or even 2gc 2 bbls I carried a spare accelerator pump. Seems they failed about every 5 years, even more if it sits and they dry out.
Old 06-05-2015, 07:25 PM   #4
osaltyone
osaltyone's Avatar
good to know, thanks! I have an old rebuild kit NIB that I found in a box of stuff in the truck, guess I have something to do tonight.
Old 06-06-2015, 08:04 AM   #5
SCHRUMGMC
SCHRUMGMC's Avatar
Either a carb or leak. My leak was at my gas tank and I tightened down the fitting near the sending unit and it ran great
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 06-06-2015, 09:29 AM   #6
OrrieG
OrrieG's Avatar
Easy to check, pull air cleaner and look down throat. Move throttle and you get s squirt or gss if its good, little or none if bad.
Old 06-07-2015, 11:24 AM   #7
mr48chev
mr48chev's Avatar
Hitting the throttle and having it die or falter and pick up and go is normally accelerator pump related. Having to keep the choke on part way to keep it running is vacuum leak related.
My ongoing truck projects:
