Old 06-08-2015, 05:32 PM   #1
The Rocknrod
Moderator
The Rocknrod's Avatar
Trans Mount Question
What kind of trans mount is this? And will it work for a automatic trans behind a 350ci with a low hump cab?:
Old 06-08-2015, 06:04 PM   #2
Classic v6 GMC's
Classic v6 GMC's's Avatar
Re: Trans Mount Question
It looks like a 70's or 80's transmission cross member.
Classic v6 GMC's is offline   Reply With Quote
Old 06-08-2015, 07:49 PM   #3
The Rocknrod
Moderator
Thanks Classic.
Anyone ever use one for the installation I talked about above?
Old 06-08-2015, 08:11 PM   #4
Classic v6 GMC's
I have not seen anyone use one on our year trucks but it could probably be made to work.
Old 06-08-2015, 08:19 PM   #5
padresag
http://www.persh.org/pickup/700R4.htm
ron
padresag is offline   Reply With Quote
Old 06-08-2015, 09:45 PM   #6
The Rocknrod
Moderator
Originally Posted by padresag View Post
Thanks Ron,
Do you think thats a low hump or high hump being used with the 700R4?:
Old 06-08-2015, 09:52 PM   #7
padresag
you can use a low hump but you have to massage that lip under the floorboards under the firewall
ron
Old 06-09-2015, 01:33 AM   #8
Captainfab
60-66 Nut
GM started using that style of trans crossmember around '79. The style of trans crossmemner is not dependent on whether a low hump or tall hump is used. The low hump will work with most automatics, but sometimes the lip at the front needs to be massaged as Ron mentioned.
That trans mount shown in the pic looks awfully tall.
Old 06-09-2015, 06:07 AM   #9
The Rocknrod
Moderator
Lip Aye.
Thank you Cap'n
Yes they both look tall, that's why I was wondering if it'd work.
