Old 02-11-2004, 09:57 PM   #1
'70 C/10 SS500
'70 C/10 SS500's Avatar
fan shroud...
Longhorn Man, yes, I've been planning to modify the stock Caddy Deville fan cover with the emissons/timing specs sticker to act as a "finger protector" for my fan. I don't know if I'll make a full blown shroud or not but definately a protector is in the works. I'm going to make a duplicate bracket like the one that supports the upper rad. hose and mirror it to the other side and catch the other original a/c bolt hole boss on the manifold and the inside bolt of the pass. side radiator bracket. With those two brackets in place, it's simply going to lay across them on top as sheet metal and act as the protector. The stock Caddy sticker will be centered on the plate and give a little hint to the less Caddy familiar eyes.
Also, my turn flasher is only about a year old and worked just fine before I started the motor swap.
'70 C/10 SS500 is offline   Reply With Quote
