Old 06-09-2015, 03:33 PM   #601
tpimuncie
tpimuncie's Avatar
Re: My 1959 apache project
Thanks!!!
I am using a 60 gallon ir compressor with a 7 year old sata jet gun, im in no way a pro painter I took a painting class one semester at out local college in 1999 and the rest has just been trial and error. I love painting hate bodywork but I do it because id rather see my own flaws then pay to see someone elses. Thanks for all the positive comments on my build I really appreciate all the input. its been triple digit heat over here in northern ca so im taking a break until it cools off a bit.
1959 apache 1948 chevy coupe
http://67-72chevytrucks.com/vboard/s...d.php?t=562949
1964 gmc burban build for pops
http://67-72chevytrucks.com/vboard/s...d.php?t=724632
tpimuncie is offline   Reply With Quote
Old 06-09-2015, 03:55 PM   #602
Whumbachumba
Whumbachumba's Avatar
Thanks tpi. Thinking this might be a better option for us than sending it out and having it painted. What type of primer did you use?
-Scott
1955 Chevy build
Whumbachumba is offline   Reply With Quote
Old 06-09-2015, 06:21 PM   #603
lowrodderchev
lowrodderchev's Avatar
Originally Posted by tpimuncie View Post
Thanks!!!
You doing a super great job trucks looking real sweet
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 06-10-2015, 01:34 PM   #604
tpimuncie
tpimuncie's Avatar
Its a ton of work to do your own vehicle, strip to bare metal, epoxy, rust repair patches, bodywork, blocking, prep for paint, shoot it, color sand it, buff it I just refuse to pay thousands for work I can do myself and lets face it there is no such thing as a perfect paint job/body work so id rather see my own flaws then pay to see someone elses every time I get into my truck.
I used 5 star xtreme high build primer (black) I love it because I can test it with water to see if theres any major flaws.
Old 06-10-2015, 01:37 PM   #605
tpimuncie
tpimuncie's Avatar
Thanks!!!!!!!!!!!!! im trying
Old 06-14-2015, 04:47 PM   #606
tpimuncie
tpimuncie's Avatar
Well was going to keep the bed holes but decided to shave them
Old 06-14-2015, 04:49 PM   #607
tpimuncie
tpimuncie's Avatar
Since i need to raise bed floor 2" to clear everything im taking old cross member cutting it and welding it to existing cross member to give it that factory look.
Old 06-14-2015, 06:21 PM   #608
Kim57
Kim57's Avatar
Looks good with the pockets filled.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 06-15-2015, 05:23 PM   #609
RockinKees
RockinKees's Avatar
You're a true Craftsman!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 06-16-2015, 08:49 AM   #610
TypeSL2
I didn't see anywhere that you mentioned it, but what is the name of that color? That is a gorgeous color.
James
TypeSL2 is offline   Reply With Quote
Old 06-16-2015, 10:56 AM   #611
tpimuncie
tpimuncie's Avatar
Kim
Thanks!
Just a garage warrior lol thanks!
James
Its called "neptunium green" Nissan color not sure of the year, thanks!
Old 06-18-2015, 01:00 AM   #612
tpimuncie
tpimuncie's Avatar
So i cut up the original cross member i removed glad i never tossed it because it came in very handy
Old 06-18-2015, 01:02 AM   #613
tpimuncie
tpimuncie's Avatar
Trimmed it tacked it in place on back side, trimmed front
Since the tailgate rubbed on bottom and welded in flat steel plate
Old 06-18-2015, 01:04 AM   #614
tpimuncie
tpimuncie's Avatar
My goal is to raise the wood floor just enough to clear everything which is only 2" and still have that factory look. Should be all done by weekend then continue with bed bodywork so i can paint bed
Old 06-18-2015, 02:20 PM   #615
Kim57
Kim57's Avatar
Good idea on raising the bed floor.
Kim
My build thread
Old 06-19-2015, 01:35 AM   #616
tpimuncie
tpimuncie's Avatar
Old 06-19-2015, 05:22 AM   #617
RockinKees
RockinKees's Avatar
Looks good!
Looks like it's original
Cheers!! Kees.
Kool Guyz CC
Old 06-19-2015, 09:02 AM   #618
lowrodderchev
That came out real nice
Old 06-19-2015, 10:48 AM   #619
tpimuncie
tpimuncie's Avatar
Thanks! im not planning on dropping the tail gate ever so its just going to be covered
Old 06-19-2015, 02:31 PM   #620
Advanced Design
Advanced Design's Avatar
Stake pocket fill and the cross member looks really good! Nice work and realling enjoying your progress.
Advanced Design is offline   Reply With Quote
Old 06-21-2015, 04:13 PM   #621
tpimuncie
tpimuncie's Avatar
Thanks!!
Happy Fathers Day to all the Dads!
Old 06-21-2015, 04:14 PM   #622
tpimuncie
tpimuncie's Avatar
Im really happy with the results so far! I have to trim the tubs a but for a flush fit on the sides make some template extensions so thy can be bolted in with all bolts and be flush.
Old 06-21-2015, 04:27 PM   #623
Kim57
Kim57's Avatar
Looking real nice.
Kim
My build thread
Old 07-01-2015, 12:01 AM   #624
tpimuncie
tpimuncie's Avatar
Interior kit arrived
Old 07-01-2015, 12:02 AM   #625
tpimuncie
tpimuncie's Avatar
Added visors and armrests late to the order so this will be in later
Also not sure if i mentioned i will be removing the air bag suspension and will be going with hydraulics
