06-13-2015, 06:54 PM | #1 |
So you want patina.....
You want to build an original looking truck with an aged look to it. No expensive paint and body. A trucks finish is only original until someone starts sanding and priming it. Then is gone. Never original again. You're building a custom sleeper with state of the art aftermarket suspension. And maybe an interior that has a few creature comforts and a really cool set of wheels. Its a Chevy so it will naturally have a reliable drive train. You want a medium blue but can only find that blue with the aged look you're after in a long bed and you're building a short wheelbase fleetside truck. The challenge. Cut down the long bed bedsides to short bed bedsides and do it without bondo or primer. Keep as much of the original finish as possible. Maybe just a dusting of color over the welded joints so its not eye grabbing obvious. Let's see what we can do.
06-13-2015, 06:58 PM | #2 |
Re: So you want patina.....
These are for veteran truck builder ATP so it should turn out nice. Can't wait to see what he has up his sleeve on this build!
06-13-2015, 07:41 PM | #3 |
Now thats talent. Very nice!
06-13-2015, 07:58 PM | #4 |
that's amazing
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
06-13-2015, 08:17 PM | #5 |
That came out great. Very nice work.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
06-13-2015, 08:37 PM | #6 |
That came out really nice. Great job
06-13-2015, 08:47 PM | #7 |
looks good
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 |
06-13-2015, 09:16 PM | #8 |
Nice work
06-13-2015, 10:27 PM | #9 |
Looks real good
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
06-13-2015, 10:54 PM | #10 |
laying low
That's some fine cuttin and stichin right there. I am enjoying seeing what methods all you guys come up with for shortening these bedsides. Talent and patience. I love it. Thanks for sharing.
06-13-2015, 10:56 PM | #11 |
That is freaking awesome! I thought it was trickery at first, until I looked really good.
06-13-2015, 10:57 PM | #12 |
Your using ESAB Easygrind .023 correct? could you please tell me the heat and feed setting your using and the diameter of the individual spot welds please. Send a PM if you wish, Thanks.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
06-13-2015, 11:02 PM | #13 |
Can you give us a peek at how you did the front!!!
06-13-2015, 11:39 PM | #14 |
Yes easygrind .023 I like to bounce around on the heat. Fast wire feed because its thin wire and soft. I like to hit each weld hot and fast so penetration will be good and keep the haz to a minimum. As far as diameter, 1/8th ish. These pics may help.
06-13-2015, 11:40 PM | #15 |
Those are mig welds on some nasty scrap.
06-13-2015, 11:48 PM | #16 |
But on the body work you are using spot welds right, the picks look like your laying a regular weld. Thanks for the reply.
06-13-2015, 11:54 PM | #17 |
Both the same, just a little slower on the bedside to help control the heat.
06-14-2015, 12:01 AM | #18 |
I'll show the front Monday. That's the easy part. It's just 12 inches from the leading edge. I need to get some color that is closer because the blues I have in the shop need a bit of green in them. When the color is closer and its out in the weather a while, should start to look real good.
06-14-2015, 12:23 AM | #19 |
67-72 parts collector,…
ebfabman,... have you seen this thread?
http://67-72chevytrucks.com/vboard/s...d.php?t=667694 Totally different approach to shortening a 67-72 bed. I'm sure you could pull this method off also, with your welding skills.
06-14-2015, 12:50 AM | #20 | |
