Old 06-11-2015, 06:49 AM   #26
1project2many
Re: TPI in my 51 GMC
The intake will limit power. The main factor is the small runner size which limits airflow. A smaller displacement engine will run to higher rpm, 5200 or so with a 302, while a 383 can see a peak as low as 4200. There is an aftermarket version of the TPI based on a system by Airsensors / F.I.R.S.T. which will support more power / higher rpm but they're spendy. They were offered as a standalone system with a fuel only computer and were also sold through B&M as "Superjection."
Leftover NOS from this defunct company was for sale through a website called auto-nomics but I see they've sold their inventory to first performance. There's plenty of reading on the auto-nomics site and you can view some neat installations and current offerings on the first performance site. Personally I'd use a factory GM ecm with this manifold but standalone kits are available.
1project2many is offline   Reply With Quote
Old 06-11-2015, 11:49 PM   #27
Softpatch
Softpatch's Avatar
congrats nice job
I had an howell injection system on my 64 and can tell you it was not a success did not have any fun a real wallet burner.... howell system soured me
it was definitely not plug and play
My Spelling is Not Incorrect...It's 'Creative'
1966 C-20 .....Swap 91 G-30(5.7 FI)/4L80E
http://67-72chevytrucks.com/vboard/s...d.php?t=789617
59 Viking Revival .. http://67-72chevytrucks.com/vboard/s...d.php?t=632341
Softpatch is offline   Reply With Quote
Old 06-12-2015, 10:29 AM   #28
solidaxel
solidaxel's Avatar
I just picked up a 87 350, checked the casting #'s and that and the computer tells me that everything is a 350CI.
The question I have for those of you that have had good luck with them is...... I want to start the engine, but I have no idea which wires I need in the harness I need to start ONLY.
There is a 700R attached to it and all wiring is attached all the way to the computer.
Where do I start ? pun intended!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 06-12-2015, 12:12 PM   #29
Katrina/10
Katrina/10's Avatar
Is it removed from the truck? Everything on the engine needs to be plugged in, and there are two 12v wires to the battery. It will run without the O2 sensor, and of course you will need to hotwire a fuel pump.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-12-2015, 12:34 PM   #30
solidaxel
solidaxel's Avatar
Thanks, All the connections are still on the engine I have removed the body and front sheet metal so it is just a rolling chassis
LS 3 4L70E
Old 06-12-2015, 03:31 PM   #31
twinsemi
twinsemi's Avatar
Since you say it is an 87, from the picture alone, you will need to add the MAF sensor. ECU has a couple BAT leads and some IGN leads. You can find the wiring diagrams on the web. You will need to know your ECU number to make sure you don't fry something.
twinsemi is offline   Reply With Quote
Old 06-12-2015, 03:39 PM   #32
solidaxel
solidaxel's Avatar
I think I need to get out of Katrin's site and start my own.
Thanks for the help
If you don't mind I will add the numbers from the computer
Service #01227165
It has a SuperChip #8820 B installed
The casting numbers on the engine block
14610207
LS 3 4L70E
Old 06-12-2015, 04:28 PM   #33
Katrina/10
Katrina/10's Avatar
No problem, if you are the one taking it apart, you can see where all the wires go. It will really help you if you download the FSM wiring diagrams for the car you are taking it out of.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-12-2015, 04:30 PM   #34
Katrina/10
Katrina/10's Avatar
Thanks for the help
Service #01227165
14610207
No problem, if you are the one taking it apart, you can see where all the wires go. It will really help you a lot if you get a copy of the FSM wiring diagrams for the car you are taking it out of.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-13-2015, 05:42 PM   #35
docrock
docrock's Avatar
this is very cool. I have two of these intakes and a harness with computer. I was going to toss them but now maybe not. I started a 42 flatbed that might look cool with this setup. Dont you need the whole gas tank also with a 40 psi fuel pump?
In my 54 I have the whole harness and chassis with the 4l60e and 5.7. Runs great now.
1954 GMC on 93 Silverado chassis http://67-72chevytrucks.com/vboard/s...d.php?t=408344
1942 Chevy 1/2 ton Pickup http://67-72chevytrucks.com/vboard/s...d.php?t=429494
R.I.P. TOM SEFFRON 68 FOUR DOOR http://67-72chevytrucks.com/vboard/s...d.php?t=495438
1942 Chevy that ate my brain 70 Chassis https://67-72chevytrucks.com/vboard/...d.php?t=835250
docrock is offline   Reply With Quote
Old 06-14-2015, 07:43 AM   #36
Katrina/10
Katrina/10's Avatar
Don't throw them away, somebody could use them! They really do look cool and work well in a truck. I used the original tank, with an inline electric pump.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 06-14-2015, 10:31 AM   #37
Rickysnickers
1project,
I looked at the website, https://www.firstfuelinjection.com/services.html. Man they are pretty proud of those parts! They are expensive.
Old 06-14-2015, 03:34 PM   #38
1project2many
Yes, they are very expensive. But they are the only long runner, TPI style intake I'm aware of that can produce 500+ hp n/a. And I *believe* they have a vortec base available now. Look at pricing for the stealth ram.
You could always use a stock unit and add turbo / supercharging.
Old 06-14-2015, 09:17 PM   #39
mobileortho
mobileortho's Avatar
I have it in my truck. Found a good deal on the Edelbrock intake and runners so I swapped those as well.Name:  image.jpg
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
