Old 06-14-2015, 10:47 AM   #1
Steve Cole
Can someone explain how/why this happened ???
So yesterday was a real scorcher, about mid 90's most of the day and 40% humidity. My plan for the day was to drive my truck to a local cruise-in but first we had to stop by the mall to pick up some new glasses for my wife. We locked the truck up and went inside for about an hour. Up til this point, everything was working fine. When we left the mall, we had driven about a 1/4 mile before I noticed my tach was on 0. We drove about 6 miles to the cruise-in and the tach needle never moved from 0. When I got there I shut the truck off and started checking/wiggling connections at the fuse box and back of the tach, all seemed tight so I started the truck and still nothing. Checked the connection at the HEI and started again, nothing. I stayed at the show about two hours then drove the 15 miles home, on 0 the whole time. I parked in the garage and started searching posts here on the board trying to figure out what happened. The only thing I could find was that if not properly grounded, the tach circuit board could get fried, and I also found a mention that the tach doesn't like heat, for whatever reason. Anyway, the truck sat for about thirty minutes during this and after reading several posts, I thought my newly installed OEM tach was fried. I went out to the garage and started the truck and low and behold, the tach was working! ??? Relieved, I made and installed an additional ground wire on the back of the tach.
My question is, how could it read zero for so long then start working again? I thought it was a goner for sure! Thanks,
Steve Cole is offline   Reply With Quote
Old 06-14-2015, 07:19 PM   #2
Steve Cole
Drove it about 15-20 miles, no issues. Anyone have a theory?
Old 06-14-2015, 08:01 PM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Can someone explain how/why this happened ???
I would still guess ground. There is a ground wire that clips onto the lower pinch weld of the dash that can have intermittent contact. It goes to the cluster connector. It grounds the instrument panel and circuit board. Usually it will affect other components of the cluster too though.
My best guess....
LockDoc
Leon
Old 06-14-2015, 09:12 PM   #4
jjzepplin
jjzepplin's Avatar
That's it. I am going to connect up a soldered eye on that wire and bolt it to the dash before I put my tach in. Should I run a dedicated grnd wire to the dizzy too?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 06-14-2015, 09:24 PM   #5
LockDoc
LockDoc's Avatar
I don't think you would need to. The bolt and clamp should provide a good enough ground for the distributor.....
LockDoc
Leon
Old 06-15-2015, 09:09 AM   #6
Steve Cole
When I got home that day I made a ground wire that connected at the back of the tach and went to some structure under the dash just to make sure I had a good ground in the future. Thanks for the replies.
