Old 06-17-2015, 10:34 AM   #1
Chris Coufal
Air intake tube options
What are you guys using for airtube and filter? Battery is being moved to the back....so I can go left or right. Going into a 66 with an LQ4.
Chris Coufal is offline   Reply With Quote
Old 06-17-2015, 10:45 AM   #2
jackyl9999
jackyl9999's Avatar
Re: Air intake tube options
I used a stock airbox setup. Cheap and easy to find.
1970 Gmc Grande Sierra Swb 2wd LSX (LQ4/4L80e)
1990 K1500 Daily
jackyl9999 is offline   Reply With Quote
Old 06-17-2015, 11:18 AM   #3
KMC3420
KMC3420's Avatar
I Plan on using this. TRKFRK used it.
Amazon.com: GMT800 V8 Truck/SUV 4" Aluminum... Amazon.com: GMT800 V8 Truck/SUV 4" Aluminum...
http://67-72chevytrucks.com/vboard/s...424609&page=21
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 06-17-2015, 12:31 PM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
A perfect segue for me to insert myself lol
Moving the battery
Building an air box for an ls swapped c10
*I have pics in my build of the intake kit I started with. Its the 2004 Silverado cold air intake which you can easily find in 50 version on ebay for under $50...which has had the tubes flipped and brackets trimmed. I did add an additional bend from Spectre, but only because my intake had been modified already once before. But its possible to make a functional intake with just the cheap Silverado kit by itself.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-17-2015, 01:19 PM   #5
Chris Coufal
Thanks for the videos. What engine cover is that off of? I have the basic Vortec one and don't like it.
Old 06-17-2015, 01:40 PM   #6
mongocanfly
mongocanfly's Avatar
I used spectre fittings and filter and 4" mandrel bent alum tube...got everything i needed off ebay.
Old 06-17-2015, 03:43 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
No problem. The cover is the 3-piece vortec max cover. It came on some of the Denali's, Yukon XL's, and I think a couple of the high-option package trucks. Its the same basic cover as the "vortec 6000" and Cadillac 3 piece covers, but the center just has "Max" on it instead of something else. Lettering was just hand painted on since everyone kept asking what size motor it was.
Old 06-17-2015, 06:55 PM   #8
lutronjim
If you are using MAF sensor, make sure you have 4" tubes. I got a unit off Ebay that downsized from 4" to 3.5" at the throttle body and kept getting codes. Changed to 4" and no more problems.
lutronjim is offline   Reply With Quote
Old 06-17-2015, 07:37 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The throttle body and MAF are 85-92mm depending on exact combo, either of which shouldn't have a problem with a 3.5" tube (87mm is ~3.4")
Are you sure it was the tubing size that caused the issue, not the actual placement of the MAF in relation to the tubing and bends?
Old 06-18-2015, 12:12 AM   #10
Chris Coufal
where should the MAF be placed within the tubes?
Old 06-18-2015, 02:06 AM   #11
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
So despite the math actually working, I was looking at another manual from a crate engine which actually does list a 4" diameter tube. Though it doesn't rule out a 3.5", it does specifically refer to a "4" tube. I've got the text below.
You want it in a straight run of tube, with at least a few inches before any bends or any portion which may create turbulence. This includes keeping it far enough away to avoid turbulence from the throttle body. Here's the reference from gm:
Ensure the MAF sensor is oriented correctly in the induction (it will
only read correctly in the proper direction). An arrow is located on the
sensor indicating correct flow direction. Verify this before welding the
mounting boss, as the sensor will mount only one way in the boss.
Ensure the MAF Sensor is mounted in the middle of a minimum 6 inch
length of 4 inch diameter tube, and is a minimum of 10 inches from
the throttle body."
Old 06-18-2015, 09:12 PM   #12
Robznob11
Robznob11's Avatar
I used two eBay Silverado kits with a k&n. Mass needs to be in the longest straight section of pipe at least 10" away from the tb for best results.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-18-2015, 10:52 PM   #13
dayj1
The advice that you've been given so far is good and is directly in line with the GM recommendations, but I found that MAF placement was quite forgiving in my case. I attached the MAF directly to the throttle body and it runs great and has never thrown any codes.
dayj1 is offline   Reply With Quote
Old 06-18-2015, 11:20 PM   #14
Robznob11
Robznob11's Avatar
Mine was directly on tb too and seemed to be fine , that is until I dropped a cam in it. Then it started running lean and popping through the intake.
LED TAILS
Old 06-19-2015, 08:53 AM   #15
Andy4639
Old member
Andy4639's Avatar
Mine on the 6.0 in the 71.
Hole cut in support for the cold air.
90 model Caddy box modified for it.
Lowes ninty and 2 couplings.
Mounted in the truck.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 06-19-2015, 08:26 PM   #16
Chris Coufal
thanks
Old 06-21-2015, 03:31 PM   #17
kitsbeach
kitsbeach's Avatar
Okay that is a very cool setup..!!
And what are those valve covers and/or heads with the perimeter bolts..??
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline   Reply With Quote
Old 06-21-2015, 04:38 PM   #18
dayj1
Thanks. That's plain SBC valve covers on stock 4.8 heads. The magic is valve cover adapters from ICT Billet. My engine swap thread is here: http://67-72chevytrucks.com/vboard/s...d.php?t=668385
