Old 06-17-2015, 06:15 PM   #11
Hblee
Hblee's Avatar
Re: 1957 Chevy truck re-rebuild
It is untouched. I'm planning on using the short BB water pump like is on my Corvette and electric fans but I have a feeling that it's gonna be a tight fit. I need to get a bare block with heads and mock it up before I do the motor mounts. I just need to make sure it's not mounted too low.
Just bought a new Millermatic 211, it has great reviews and allegedly even a beginner like me can make some pretty welds. Can't wait to get started.
Originally Posted by Stepside Jim View Post
Yes, the clearance between the firewall and valve covers was very important, also important to me was not altering the firewall. I simply hate messing with interior work, well, mainly stuff having to do with fabrics, this includes messing with carpet, so I know if I changed the firewall in any way I may have to mess with the carpet. This way I ordered the carpet, and it fit.
Of course, not messing with the firewall meant the engine did have to sit forward slightly. I went with the dual electric fan set-up, this allowed the water pump hub to fit between the two electric motors of the fan set-up.
My only issue was finding the right set of front springs to support the front of the truck, it took a couple of springs but by using the Moog spring specification online catalog I found a set that is keeping the truck right where I want it to be.
On the other hand, no matter where the engine was located the correct springs was going to be a challenge.
Hope this helps, with the 427 you'll be right in the thick of it soon. When your frame was done, was it kept original or was it altered for a different front suspension?
Don't pay no mind to that whirrin' sound, she uses a little oil but outsida that she's cherry.
Hblee is offline   Reply With Quote
