Old 06-18-2015, 07:17 PM   #1
enamelplanet
enamelplanet's Avatar
Custom engine color
What would be a good choice for a custom engine paint.
I'd like to paint it the body color. Is there a tintable engine paint available? Will any other paint hold up?
64 Fleetside, Shortbox, BBW
66 Fleetside, Longbox, 4x4 SOLD
70 5.3, Fleetside, Shortbox
enamelplanet is offline   Reply With Quote
Old 06-18-2015, 07:47 PM   #2
cdowns
cdowns's Avatar
Re: Custom engine color
auto partsstore has racks with all type of colors for engines
Old 06-18-2015, 08:01 PM   #3
tinydb84
tinydb84's Avatar
Eastwood makes high temp 2k engine paints.
You can use regular 2k urethane though.
David
Instagram: myfabguy
Old 06-18-2015, 08:04 PM   #4
enamelplanet
"auto partsstore has racks with all type of colors for engines"
I know that.
I need 504 Yellow green. It will need to be mixed but I don't know of a tintable engine paint. I'm asking for the best alternative to a engine specific paint that will hold up. If there is one.
Old 06-18-2015, 08:57 PM   #5
Hogshooter
You can paint it with single stage enamel with hardener (Centari) just prep the block well, clean clean and then clean one more time. I use epoxy primer then BC/CC over that and have had no issues.
Hogshooter is offline   Reply With Quote
Old 06-18-2015, 09:15 PM   #6
hugger6933
X2 on the epoxy primer. I have heard but have not done this that a couple coats of high build will help smooth out the casting of the block and heads. I know if that would hold up it would save a bunch of hours trying to smooth out the flash and all of the casting marks. I takes FOREVER to smooth out a block and set of heads to make them all smooth and pretty. If anyone has tried the high build over the primer I'll hope they will chime in and say how it worked I too would like to try it but no custom for me just good old Chevrolet Orange. Jim
hugger6933 is offline   Reply With Quote
Old 06-18-2015, 10:12 PM   #7
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
All I use is is epoxy then base coat and a good clear.. Never any problems.
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 06-18-2015, 10:15 PM   #8
firedemon
i am not a pro painter but have painted my fair share of stuff . i believe most automotive paint is able to withstand 500 degrees so any should do ok . if your engine is over 500 your in trouble headers and exhaust in general needs the high heat . i have found single stage holds better on engines the clear in base coat/clear coat tends to yellow over time with the heat cycle . probably why most people think you need heat paint .
firedemon is offline   Reply With Quote
