Old 06-18-2015, 06:38 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
250, no oil pressure
Started the 250 after sitting for 4+ years and it ran great. Drove it down the street and it began to sputter and then backfired. Pulled it back to the garage and found the distributor was loose. Set the timing position as it always was pointing and the truck started right away. BUT, now there's no oil pressure.
Pulled the distributor and the tongue on the end of the shaft is still intact. Installed another oil pressure gauge, no pressure.
Started and idles great.
Did something to the oil pump?
Dropped the pickup tube?
Old 06-18-2015, 09:13 PM   #2
hotrod66
hotrod66's Avatar
Re: 250, no oil pressure
Have you tried using a priming tool to spin the pump ?
Between saying and doing many a pair of shoes are worn out
hotrod66 is offline   Reply With Quote
Old 06-18-2015, 11:19 PM   #3
WOLFMANmike
WOLFMANmike's Avatar
ohh i think its time to drop the oil pan .. that sounds like pump failure or at the least a pump pickup tube has fallen off the oil pump . at any rate i would not run the engine untill that is fixed as you will eat up your crank and rod bearings in short time ... also just try to put in a aftermarket oil gauge to see if its the gauge but i doubt it .. im thinking its pump related
WOLFMANmike is offline   Reply With Quote
Old 06-19-2015, 05:45 AM   #4
aerotruk63
aerotruk63's Avatar
No, I did not try a priming tool as suggested. Time to make one.
Tried two other pressure gauges without success.
Old 06-19-2015, 07:56 AM   #5
Lokin4AReason
Lokin4AReason's Avatar
priming the pump helps ..
also cheque the clearance of the pickup to the oil pan ... it might need to be adjusted
dont want to hear excuses, i want to hear solution(s)
Lokin4AReason is offline   Reply With Quote
