Old 02-12-2004, 11:50 AM   #1
mindhive
No high range in T/C?
I have an 86 c-10 4X4 M/T that I can only get into 4 low. Any common causes for this. Also I was wondering what tranny and T/C should be under there for that year. I don't hane any literature on this truck at the time. Thanks for the help.
mindhive is offline   Reply With Quote
Old 02-12-2004, 03:19 PM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Should be a NP208 part time transfer case. Can you shift it into 4 hi or 2 hi? Or will the shifter not move? If it does move check to see if the linkeage is disconnected.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 02-12-2004, 03:32 PM   #3
drink2mny
drink2mny's Avatar
I second that.. Should be
tranny- 700r4
transfercase- np208 part time
You say you can get it to 4lo but not hi??
Is always stuck in 4 lo, because if your able to shift back from 2hi and just doesn't engage or stay in 4 hi, you need to check the linkage.. If it is off a little bit they will not engage or stay engaged in 4 hi..
If it isn't even coming out of 4lo to shift forward in 2hi at anytime and the linkage is fine. Then you may have internal problems..High miles on the transfercase strech the chain inside and makes evry other componant in there not work properly...
Hope this helps.
Support The Board
drink2mny is offline   Reply With Quote
