Old 06-19-2015, 11:14 AM   #26
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Lets talk about wide 20s
Here's an example of a 315/35/20 on a 20x12 rim. The stance on this truck is tuned perfectly to the tire size. I do feel that the tire looks to be a bit stretched on a 20x12. I feel that the 20x10.5 I am looking at might be about right.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-19-2015, 11:23 AM   #27
N2TRUX
Happy to be here
N2TRUX's Avatar
Since we are talking squarebody here's another example of a 295/40/20 on a 20x10. I feel it has a fantastic stance and great proportions, I just want a bit more width.
Articles-
"Refining Sierra"
Old 06-19-2015, 02:14 PM   #28
muthstryker
muthstryker's Avatar
Yep the 295/40/20 is the absolute perfect example of tire hieght on these trucks! Which is why I personally chose the 29" MT tire, its practically the same height just wider.
Matt
muthstryker is offline   Reply With Quote
Old 06-19-2015, 02:32 PM   #29
muthstryker
This truck was in truckin mag around 2010 I believe, he has the 18" wide tire but its still the 29" tall MT
Matt
Old 06-19-2015, 02:59 PM   #30
lolife99
67-72 parts collector,…
lolife99's Avatar
That's an old picture of Jose Pena's truck, Black Widow".
(from Drops R Us fame)
It now runs 24x15's all the time.
Lots of rear suspension mods.
Keith
Convert to disc brakes.
Old 06-19-2015, 03:22 PM   #31
RUN GMC
RUN GMC's Avatar
Im liking this since I too plan to do a wheel change with same issue no alterations just using back spacing and width........but would like to see more squarebodies for the practical application......but still great info.........
RUN GMC is offline   Reply With Quote
Old 06-19-2015, 06:43 PM   #32
muthstryker
Yep! I had to dig deep for those older pictures!
Matt
Old 06-20-2015, 08:04 PM   #33
87squarebody
87squarebody's Avatar
Subscribed.
87squarebody is offline   Reply With Quote
Old 06-21-2015, 11:40 PM   #34
rwade
rwade's Avatar
Who makes the wheel on the black 67-72 chevy truck? Can you get different backspaces? What sizes are available?
Wade
rwade is offline   Reply With Quote
Old 06-22-2015, 07:52 AM   #35
N2TRUX
Happy to be here
N2TRUX's Avatar
3Rwade those are American Racing VN 327 Rally. They are available in several sizes,widths, and backspace. Those are 20x10 in front and 20x12 in back.
Articles-
"Refining Sierra"
Old 06-22-2015, 02:20 PM   #36
Hart_Rod
Hart_Rod's Avatar
Ken I ran the Mickey Thompson 31x16's on my 12" rims on my gold 68 with no problem. I had a 7" backspacing on the rear wheels and a 5" backspacing on the front and I think they looked propostional. I'm running a 295/45/20 (30.5" tall) on the back of my green PB truck. The fronts are 255/40/20 (28" tall). I don't like running rubber bands either and I like the Big/Little look.
Hart_Rod is offline   Reply With Quote
Old 06-24-2015, 10:52 AM   #37
N2TRUX
Happy to be here
N2TRUX's Avatar
Thanks for sharing Hart_Rod. Its good to know that the 12s will clear on the 67-72s with no issues. My nemesis "might" be the RideTech 4 link mounts the bag outboard, so I need to verify that a 20x12 will clear.
I am currently researching 315/35/20's that have a matching front in a 245/40/20 or 255/40/20. What I am finding is that there is a huge variance in the profile of the tires between brand, and series. It seems the taller 315's are narrow, and the wider 315's are short. I'm still trying to find the right combo.
Articles-
"Refining Sierra"
Old 06-25-2015, 07:14 PM   #38
N2TRUX
Happy to be here
N2TRUX's Avatar
As expected, the advertised size has nothing to do with the actual size of a tire. I have found it almost impossible to locate pictures of a specific brand, series, and size mounted on different width wheels to compare. I have resorted to finding unmounted pics to get some sort of visual perspective on what various tires will work.
Heres a perfect example of what I am up against. The truck has a Michelin Pilot Super Sport 315/35/20 on a 20x12 and the Camaro has a Nitto Motivo 335/35/20 on a 20x11. Of course the 20x12 should make the tire look wider, but it shouldnt be an insane difference. Clearly the Michelin Pilot Super Sport is a much bigger tire all around.
Articles-
"Refining Sierra"
Old 06-25-2015, 09:57 PM   #39
BossHogg69
motor exploder
BossHogg69's Avatar
That tire on the Camaro looks nothing like a 335 to me, much less on an 11" wheel. You would think a 335 would have a lot more sidewall bulge or look 'pinched' on an 11" wide wheel. I'm running BFG KDW 335/30/18's on 18x12's on my '69 C10 and they look WAY wider than whats on that Camaro.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-26-2015, 07:54 AM   #40
N2TRUX
Happy to be here
N2TRUX's Avatar
Thats my point Bosshog69. It's a huge frustration to research a brand, series, and size to fit my criteria of front and rear size only to find xyz brand or series runs very narrow, or short compared to the advertised dimensions.
I tried calling www.discounttiredirect.com hoping to get a a sales rep with hands on knowledge, but that failed too. I will find my answer, but it won't come easy.
Old 06-26-2015, 08:11 AM   #41
Hart_Rod
Hart_Rod's Avatar
Keep searching car shows, eventually you are going to find a truck with tire/wheel sizes that you like on it.
Old 06-26-2015, 08:41 AM   #42
BossHogg69
motor exploder
BossHogg69's Avatar
FWIW, the BFG kdw's spec out really close to the 'advertised' numbers they put out as far as overall width and tread width go.
Adam
Old 06-26-2015, 09:46 AM   #43
N2TRUX
Happy to be here
N2TRUX's Avatar
I'm trying, but the current rage is 22's or 22/24's and thats not where I want to go.
Unfortunately they dont make the sizes I need in a KDW. I am running KDW II now, but it appears that series has been discontinued.
Tread pattern is another issue to deal with. I am finding some very unattractive tread patterns that just wont work
Articles-
"Refining Sierra"
Old 07-01-2015, 09:45 PM   #44
TwinsSpeedShop
Im glad this is being discussed at length. Im currently looking at an set of raceline wheels and im torn on a 10.5 wide rim when I really want to run a 12. By measurements, a 12 should fit with no mods to wheel tubs, but if I have to narrow the rear end, im probably out. Hart, have you fit your bed with the 12's? any mods or stock length rear end and wheel tubs. My truck is a 67 5 lug but with a 71 up wider rear end. I could get a 70 down narrower rear end if that makes the difference. Great looking trucks, Im just trying to keep up!!
TwinsSpeedShop is offline   Reply With Quote
Old 07-01-2015, 09:58 PM   #45
Hart_Rod
Hart_Rod's Avatar
Wheel tubs have been widened 4", stock width 68 rear axle, 7" backspacing on the Vintecs.
Old 07-01-2015, 10:00 PM   #46
TwinsSpeedShop
awesome, thanks Hart. I can handle the narrower rear end and widening tubs to get the width. I just didn't want to narrow the rearend.
Old 05-26-2016, 05:31 PM   #47
87squarebody
Trying to post from my phone so bear with me. For discussion purposes, here's a absolutely beautiful example of what a 295/40/20 looks like on a 20x10 wheel. This looks excellent this, but I want a more width. I feel the sidewall height is spot on, with proper proportions.
Would you happen to know what size is the front tire.Thanks
Old 05-26-2016, 06:11 PM   #48
SCOTI
SCOTI's Avatar
Most likely it has 245/40's or 255/40's.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 05-26-2016, 07:05 PM   #49
lolife99
lolife99's Avatar
Don't forget the wide 345/30-20's when you are looking for tires,...
Keith
Old 05-27-2016, 08:32 AM   #50
duallyjams
duallyjams's Avatar
did you find a combo that you liked ?
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
