blood type; Retumbo
Re: Winter Project... Shop Build Tread
Those Challenger versymettric lifts are nice. We have one at work we got from Napa almost 18 months ago. Something like $3500 plus $300 install.
What are you doing for heat? Also, what about floor drainage?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
#2 | |
I passed on the drainage. The floor is flat... Drains always seem to be in the wrong spot and sloping the floor one way or the other would have lead to vehicles rolling off. |
Well finally got the oil heater installed and going. 200,000 BTU heater heats the shop just fine. 30-32 degrees outside and a nice 62 degrees inside. It only runs 15 minutes an hour to maintain the set temperature.
The good news is with oil prices so low, waste oil collectors are charging to remove waste oil. One local shop I deal with, that does not use their waste oil for heat, has given me all of their old oil. So at least this winter, I heat for free! |
