Old 06-21-2015, 10:47 AM   #19
greywuuf
Re: SO what do we know about "Big" 4x4 (10x10's)
Originally Posted by 1976gmc20 View Post
It doesn't really matter if you're going to swap in a single axle as the entire rear suspension would need to be replaced. Like I said before, it would probably be easier to just cut the frame and weld in the entire rear half of the donor truck.
The rubber pads suspensions were commonly used on log trucks. I think that they worked better in off camber situations with tall heavy loads.
I don't see why, if it all ready has a single spring pack mounted, why could you not remove the beam and u bolt the single axle where the beam pivot used to be ?
greywuuf is offline   Reply With Quote
