Old 06-03-2015, 01:28 PM   #1
thefalconer_88
drop spindle and brake advice?
I'm looking at a few options for converting my 63 c20 front end to 5 lug.
I was looking at these two kits:
http://www.classicperform.com/Store/...062SWBK5OE.htm
http://m.ebay.com/itm/331297372417?nav=SEARCH
Any thoughts?
Should I switch all the tie rods to c10 or just do the outers?
Or should i go with the special c20 spindle that fits 5 lug hubs?
The rear end is not here yet, but its from a 71 and the price was right on car-part.com
Thanks!
thefalconer_88 is offline   Reply With Quote
Old 06-03-2015, 03:29 PM   #2
ibrown50
ibrown50's Avatar
Re: drop spindle and brake advice?
I bought the eBay one from Toms Classics, I got the 6 lug version which came with drilled and slotted rotors for no extra cost, IMHO it's a great kit really good value for money
ibrown50 is offline   Reply With Quote
Old 06-03-2015, 03:39 PM   #3
siggyfreud
siggyfreud's Avatar
I would just add that you should be weary of cheap drilled/slotted rotors. They can be prone to cracking along the drilled areas, as often they're not designed to be drilled originally, and are stock rotors that have been drilled. Many companies that do that tend to drill too far towards the edge, which can compromise the rotor especially under high heat.
siggyfreud is offline   Reply With Quote
Old 06-03-2015, 05:42 PM   #4
Kyle@FTP
Do yourself a favor and call AZ Pro Performance
Kyle@FTP is offline   Reply With Quote
Old 06-03-2015, 07:17 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Personally I'd just grab some donor stuff from a 71-72, or 73-8? or just put something together. Kits give you all that stuff, but they aren't flexible, and if you want to upgrade anything you're throwing away unused parts.
Most of the "disc brake swap" happens with the spindles anyway. The bearings and little stuff are all parts-store readily available. Plus, since it runs a regular D52 caliper, you can upgrade to something like this for only a few hundred bucks. I got my Caliper setup from Scotts HotRods at a nice price.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-03-2015, 09:41 PM   #6
ol_skool_chevy
ol_skool_chevy's Avatar
Very nice set up.....what are those shocks?
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 06-04-2015, 12:51 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
QA1's
They are either ChromaStars or PromaStars, I'd have to check the invoice to tell you for sure. There aren't a ton of shocks that will fit this short of a static size, but still hold a truck. At 4" of drop, the compressed shock is only about 9.5" long, and droops to about 12-12.5"
Old 06-21-2015, 02:52 AM   #8
thefalconer_88
Originally Posted by BR3W CITY View Post
Personally I'd just grab some donor stuff from a 70-72, or 73-8? or just put something together. Kits give you all that stuff, but they aren't flexible, and if you want to upgrade anything you're throwing away unused parts.
Thanks for the advice everyone. So I've got access to a 70 c10 for parts. Those spindles should work if I change my ball joints? Can I still put 5 lug rotors on those spindles? All of the disc brake sticky threads only mention half tons, so I'm not sure....
Old 06-21-2015, 09:06 AM   #9
lolife99
67-72 parts collector,…
lolife99's Avatar
A 1970 c10 will be drum brake.
Keith
Convert to disc brakes.
Old 06-21-2015, 12:57 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Lolife Is correct. My post should say 71-72 not 70-72
Old 06-22-2015, 01:59 PM   #11
par4tom
I personally have the McGaughy's stuff myself, and anything they make are going to be hard to beat. They are USA made and bolt right up.
Look for BelAirTim on Ebay. He works at the McGaughy's plant here in Fresno. Or, hit me up with a PM and i'll give you his phone number and you can call him direct.
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 06-22-2015, 03:18 PM   #12
DANGBREG
DANGBREG's Avatar
Tom
I agree. They make good parts. No hassles either.
What I lack in stamina I make up for with bad technique
DANGBREG is offline   Reply With Quote
