06-20-2015, 02:55 AM | #1 |
Whats the most miles youve ever gotten out of a chevy 400 before a rebuild?
Just curious ive heard stories of 350s going to 300k so i was wondering if a 400 could do the same
06-20-2015, 07:54 AM | #2 |
Re: Whats the most miles youve ever gotten out of a chevy 400 before a rebuild?
The th400 in my 85 C20 has 340k miles on it. It was never serviced until 315k miles. Still shifts great, leaks from everywhere though.
04 Yukon XL 2500 w/ Quadrasteer 61 Chevy C60, 261 inline six 86 Chevy C20 2wd, Banks 6.2 05 GMC Sierra 2500hd Duramax |
06-20-2015, 10:19 AM | #3 |
Dusty, you're talking 400 small block aren't you? Not transmission.
I think engine life comes down to how frequently the oil is changed, and how many short trips (cold engine starts) the engine has to endure. And of course, abusing the engine or overheating it won't help either. After that, I think the 400 is at a disadvantage compared to a 350. Shorter rods put more piston thrust on the cylinder wall (faster wear). The piston has to travel further for a single stroke (more wear), the piston speed is higher. The cooling isn't as good (siamesed cylinder walls). On the plus side, the main bearing journals are larger in diameter. But in the end, i suspect how the engine is cared for might count for more than the above design factors.
Greg 64 GMC Suburban - 283, NV3500, 14 bolt 77 C10 swb - 292, SM465, 12 bolt |
06-20-2015, 11:49 AM | #4 |
Greg pretty much nails it.
Personally, I have seen a 350 go 30,000 miles before it needed replacement; boy never changed his oil. Then again, I know of one that is still going with 350,000 mile but the owner cares for the truck greatly. A 400 on the other hand, the only first hand experience I have had was the one I bought out of the original 70's big body car and I believe it had around 120,000 miles. Up on tear down, everything was great, was a running engine before pull, except the outer cylinder walls had excessive wear. The kicker is im not sure how the engine was cared for. |
06-21-2015, 08:43 AM | #5 |
The one I just rebuilt for my 78 had about 270k to 280k and every thing still look good inside
06-21-2015, 08:48 AM | #6 |
And from the before pic it wasn't taken care of and a after pic all cleaned up and rebuilt
06-21-2015, 10:56 AM | #7 |
At the body shop.
Depends on abuse. I've killed the case on one, the current one has been 8 years and a hundred plus passes at the drag strip.
" That didnt make it any newer " " Dont antique the equipment " |
06-21-2015, 04:24 PM | #8 |
driving is in my blood
The OP can't mean transmission or else he would have asked about TH350 and Th400's. He asked about 350's and 400's, that means engines.
-78 c10 short/step: 388cid, M20, 5/5 drop, lots more. Playtoy and first vehicle. -98 c1500 x-cab: 5.7L, 17" rims, 5/6 drop, flowmaster, helper bags,NBS rear disk brakes. -02 Suburban 4x4: leveled front -CBR600F4i, CBR600RR, CBR1000RR, and standup skis DISCLAIMER: I cant spell for the life of me. |
06-21-2015, 04:32 PM | #9 |
Well I feel silly for not reading the first post close I see every one post and fell right in with useless info then
06-22-2015, 01:37 PM | #10 |
A motor (if that's what OP is talking about) is only as good as the person who takes care of it. If you neglect it and don't do ruitine maintenance, expect problems.
1982 Sierra Classic K15 RC/LB 6.2L Diesel 700R4 1988 GTA Trans AM 305 TPI 700R4 1993 Formula Firebird LT1 T56 1995 GMC K2500 ECLB 6.5L 4L80E 1996 GMC K3500 CCLB LB7 6L90 |
06-22-2015, 08:35 PM | #11 |
its all in care yes but it is in the way its made too. we all no that some years they changed things to save money and thats when heads crack or the rods go or what ever.
no with that said i have seen some of the mexican gm crates that are said to be junk (most are i have 4) go over 250k all the way to 375 but it was low hp the guy took grat care and used it light plus all highway driving a 70. it all plays in. i think that a real number for miles on a avage motor would be around the 150-200 make before it really should be looked at hard for a driver. if you are plaining hard work or high hp rebuild it anyway.
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph 1985 k30 "the ice cream truck from hell" no rust az truck 197-8??? c30 "ramp truck" 454 1978 monte carlo 350 350th with 2.73 gears. no rust. sc car |
06-23-2015, 10:00 AM | #12 |
My Father purchased a 1974 Impala 400 brand new. He took very good care of the car, and it lasted 350,000 miles +. Had it rebuilt, and drove it another 100,000 before selling the car. I would have loved to have it, but sold it in the car......
PROJECT TRUCK: 1985 SWB C10 Silverado Black/Charcoal, 1990 V2500 Suburban, 2018 Suburban, 2005 GMC 2500HD CCSB, 2014 Toyota Camry SE, HAD.....1968 Camaro RS/SS Family owned since new; 350 3 speed SOLD |
