Old 06-11-2015, 12:12 AM   #276
low6four
low6four's Avatar
Re: Post Pics of your Static Drops!!
Camaro sub frame front end (4 inch drop). CPP 5" drop coils for the rear.
Low6Four
'64 SWB
low6four is offline   Reply With Quote
Old 06-11-2015, 02:46 PM   #277
SnS C10
SnS C10's Avatar
Looks sweet low6four
SnS C10 is offline   Reply With Quote
Old 06-16-2015, 12:41 PM   #278
Texas1963
Texas1963's Avatar
CPP 3/5 with 1 coil cut up front. Adjustable track bar and rear shock relocation kit. After the 1 coil removal up front she was resting on rubber stops so out the stops came. She rides good and I might remove the front stop perch for some more travel.
Texas1963 is offline   Reply With Quote
Old 06-17-2015, 10:19 AM   #279
Texas1963
Texas1963's Avatar
Here's another shot.
Chief US Coast Guard Ret.
1963 SWB Fleetside Chevy L6 230
1962 Cadillac Coupe Deville 390
Old 06-19-2015, 11:59 AM   #280
Johnboy63
Originally Posted by srsummers View Post
Does someone make a stock drop spindle for our trucks? I see several trucks on here that say they have 2.5" drop spindles and still have 6 lug wheels.
Yes, I have a 6 lug 2 1/2 drop spindle that I got from classic parts 1-800-741-1678, you can also get them from LMC, Brothers, classic auto parts
Johnboy63 is offline   Reply With Quote
Old 06-19-2015, 12:09 PM   #281
forestb
forestb's Avatar
If by "stock drop spindle" you mean that will work with drum brakes the answer is no you will have to convert to disks if you want drop spindles otherwise Johnboy63 is correct.
forestb is offline   Reply With Quote
Old 06-19-2015, 12:24 PM   #282
joedoh
joedoh's Avatar
thats a looker for sure texas
Old 06-20-2015, 09:28 AM   #283
Texas1963
Texas1963's Avatar
Thanks, jondoh. I might get the 2" blocks for the rear to really bring her down.
Old 06-23-2015, 07:10 PM   #284
mooseknuckles
mooseknuckles's Avatar
my sons '63...we swapped control arms, spindles, and springs, (1 1/2 coils cut off) from my '86...removed 4 leafs from the rear springs...ordered a flip kit and c-notch, and hopefully get dropped spindles soon. currently it's dropped 2 inches in the front and probably the same in the back.
mooseknuckles is offline   Reply With Quote
Old 06-24-2015, 01:57 PM   #285
Old-Soul
I like that stance Moose. I'd like to get my 61 close to that.
Old-Soul is offline   Reply With Quote
Old 06-25-2015, 10:54 PM   #286
dwcardfan
dwcardfan's Avatar
Still got a lot to do. It has 3-5 coil spring drop with 20's
dwcardfan is offline   Reply With Quote
Old 06-26-2015, 11:25 PM   #287
revjames
Did you have to cut any of you inner fender with that?
revjames is offline   Reply With Quote
Old 06-27-2015, 09:02 AM   #288
dwcardfan
dwcardfan's Avatar
No. I have a lot of clearance.
Old 08-28-2015, 09:43 AM   #289
Don't think I ever added mine to the mix. My 64, dubbed the "Mule"
4.5/6 drop 245/60x15 & 275/60x15
Old 08-28-2015, 10:51 AM   #290
MisterC
MisterC's Avatar
Stance, wheels and tires are perfect!! That's where I want mine to end up.
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 08-28-2015, 02:58 PM   #291
rcnutt
rcnutt's Avatar
My 62 with a 71 front crossmember. 2.5 drop spindles and 3" springs in front. 5" springs in back and a half inch block to fine tune her stance. 205 70 15 front and 265 50 15 out back
[IMG][/IMG]
rcnutt is offline   Reply With Quote
Old 08-28-2015, 04:03 PM   #292
Chance66C10
My 66 with a 1-3" drop. F: 235x70x15 R: 255x70x15
1966 Chevy C10 SWB
Chance66C10 is offline   Reply With Quote
Old 08-28-2015, 04:27 PM   #293
Hollow65
Hollow65's Avatar
ECE 4/6 drop
255/55/17 front
265/55/18 rear
At my worst I'm at my best
Hollow65 is offline   Reply With Quote
Old 08-28-2015, 06:02 PM   #294
C/10 King
C/10 King's Avatar
[IMG][/IMG]
Nice truck!!!!....and the 55-56 caps are a nice touch, plus the stance is perfect also.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 08-29-2015, 12:22 PM   #295
Eric15chevys
Eric15chevys's Avatar
[IMG][/IMG]
That 62 is perfect!
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
Old 09-03-2015, 09:15 AM   #296
1FUN64
1FUN64's Avatar
64 built for autocross and daily goofing off. NoLimit Wide Ride up front with cab and front clip dropped an extra inch over frame. Rear frame rails kicked up 5" with custom mounted coil overs. Probably about 7" up front and 9-10" out back.
Love all these trucks, good job everyone!
Kent
DRIVE IT HARD, DRIVE IT OFTEN!
Short video of Black Betty & a friends 48 Panhead done by my kid.
https://www.youtube.com/watch?v=8DlAdfwDQa8
1FUN64 is offline   Reply With Quote
Old 09-25-2015, 09:10 PM   #297
slowGN
slowGN's Avatar
3.5/5 ece
slowGN is offline   Reply With Quote
Old 09-30-2015, 08:34 PM   #298
Conrad63
Conrad63's Avatar
Originally Posted by cogorman View Post
I would like to see pics of everyone static drops no matter how radical or ghetto they are. I'm thinking about buying a 5/7 drop kit from a supplier, but wanted to see one on an actual bodystyle like ours first. All I get is pics of 67-72 trucks. Also, can you guys shoot me in good directions for kits. All I have found is one supplier for the 5/7" drop. Thanks.
It would be cool if you guys had before and after too.
mines a 4-6 drop, the previous owner just heated the springs
im on 26.5 tires on 16"rims
plan to do CPP Grand slam kit with 5/7
also have a set of 22' GM Transports to go on next few weeks , which I am really excited about. anyway, here is my ride so far, not quite done, but getting there. oh and its a 63, original short wide, not a cut long box
Conrad63 is offline   Reply With Quote
Old 10-06-2015, 03:05 AM   #299
Tortuga_64
Tortuga_64's Avatar
Budget drop: Cut 1 & 1/2 coils up front and put in jeep TJ coils in rear
64 Chevy C-10
2004 VW Jetta GLI VR6
2006 Suzuki GSXR 600
Tortuga_64 is offline   Reply With Quote
Old 10-06-2015, 04:25 PM   #300
junk4cash
junk4cash's Avatar
Went with 3" cpp springs up front and 4" out back. Decided to cut one coil up front. Also removed bump stop perches but left steer stop. Rides decent and I like the look better. Sat too high up front initially.
junk4cash is offline   Reply With Quote
