Is this ultra rare or what?
So this 67 Chevy C20 CST been in my family since 68
I've looked up the vin an model number every thing checks out to factory but here's the list ( checked frame vin , cab vin ,spid vin an model # all match) I was told this is a one of a kind order made in 67 (could have been a dealer ship custom floor model) Vin CE247Z157485 C- 4x2 E- v8 gas 2- 3/4 ton 4- pu cab an bed 7-1967 Z- Fremont ca Last digits 157485 is production # (starts at 100001) so 57,485th one made To what I read they only made 50,xxx of this type so how is it higher idk model # CE20934 (from what I've read it should be CS for 67 an they didn't use CE till 68 paint code 06507AA ( I can't find any other with this paint code or this color) it's a light blue paint I've checked gm paint codes and they don't even look like this + factory option paints don't match any where close ( so was this a custom color order) 1967 C20 CST / no side markers , has CST lower trim , CST driver door badge an custom badge on pasanger side .. No badges on fender Ho52 Detroit locked 4:57s 327 4 bolt main large journal (yes factory 327 4 bolt main) Factory 4 barrel carb Power steering Heavy duty dual battery's Heavy duty 61 amp alt Turbo 400 granny low Gun rack ( I know this is common) Factory tac Camper name plate Tinted glass Aux tanks (3 in total) Deluxe air heater Aux fuel filter Aux HD rear spring front and rear shock abs Front stabilizer Push button radio Vinyl trim Chromed hub caps Small window ( I guess there where big window option for 67 befor it came standard ) Chrome front bumper and trim HD step rear bumper If any one has seen or herd of this let me know cause so far it looks like the only one of its kind I know my facts list are 100% true so don't post stuff like (oh they never did that your wrong blah blah blah) cause I'll lmfao cause like I said this is 100% factory an no the motor did not get journals enlarge or converted to 4 bolt main or a 4 barrel carb after it left the factory ... There's probably more I'm missing any help would be appreciated thanks .. Hope this is as rare as it seems |
Keepin an eye out
Re: Is this ultra rare or what?
Sounds cool...How about some pictures? You know someone was gonna ask...
1970 Chevy C10 SWB 5.3 1996 Toyota Tacoma SR5 4x4 2007 Vespa GTS 250 Scooter ZIP 91351 |
![]() Join Date: Jan 2002
They made roughly 350,000 1967 c/k-10 through c/k-30 trucks(no k/30s obviously). You're VIN falls within the total production number. The CST option is pretty cool, and its even the 327/400 combo. Super rare? No. Definitely cool and we'll optioned though
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
Oh and the CE starting your vin signifies it as a two wheel drive v-8. A CS would mean two wheel drive 6 cylinder
![]() Join Date: Jan 2007
what no speed warning??
Project "C10 Fever" (68 factory black 396 swb) Project “Faded Glory” (71 c10 med bronze original paint refresh) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
Moderator
![]() Join Date: May 2007
Many trucks were custom ordered and therefore one of a kind. I wouldn't call it rare, but if in good condition, and given the options, it would definitely be desireable.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
So it being a number matching factory 327 4 bolt 4 barrel in that mix doesn't make it rare?
Personally the 4 bolt main doesn't mean much to me. The 327 part means everything in 67 though. Biggest option motor in the pickup line until 68. I believe most were 4 bbl in the pickup. Just like in 69 when the trucks went to the 350, 99% of the 350 had a 4 bbl. I would assume most 327s are 4 bbl too in 67. The 283 would have been a 2 bbl. Like I said earlier, rare isn't the word I'd use, desirable yes. If someone wanted a 67 3/4 ton, yours is about as good as it gets. Only a few options it doesn't have that would make it unbelievable (shoulder belts and speed warning). Ive seen a few loaded 67 CST 3/4 tons. Pictures would be awesome when you get a chance
And the model number is just a generalization gm used. Your model number means 2 wheel drive v-8 3/4 ton longbox
What would something like this restored be worth ... Cause here's the story
I scrapted the 2wd frame to put cab on a 4wd frame but found out the motor was kinda on the rare side so I'm wondering if I should get that frame back from the scrap yard for a full restoration.. It only been a month hopefully if so they'll still have it ... It would be 100%. Number match stock resto .... If it ain't worth it I'm gunna build a b**chen 4x4 resto type with a few after market up grades but nothing you could really see with era correct parts |
#14 | |
There were V8s in '67s, so CE trucks were common. No big block till '68. Maybe that's where you got confused. The trim isn't specific to the CST, but it is included on those. It is an option on anything. If you have a TH400 you don't have granny low. That would be a 4spd manual.
#15 |
There is no such thing as a factory 327 4-bolt main. It is as mystical as a Unicorn. And 1967 is a small journal crank anyway so it is definitely not a 4-bolt. 1968 is the first year for a large journal 327. You can build a 4-bolt large journal 327 with a 350 block, but GM never did. What are the date codes and casting numbers on the block and heads? I see you are debating this on another post and that your block is a 3892657 which is a small journal. How do you know it is a 4-bolt? Have you had the pan off? Something is not right. I have found this morning that there was no 4-bolt mains at all until 1969-even in Z28 and Corvette! Not sure why I had never heard that before.
Also, there is no such thing as a "Turbo 400 granny low". The TH400 is a 3-speed automatic transmission. A "granny low" is a heavy duty 4-speed manual transmission with a very low first gear (like 6.55 or 7.01) that is only used to get started with heavy loads. As far as I know all TH400s have a 2.48 first gear. As far as your question about getting the frame back, it sounds like you have made some pretty extensive mods to your truck. Not sure how much value the frame will have anymore. I would just drive it and enjoy it. That is what they were made for.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project Last edited by MARKDTN; 06-24-2015 at 07:47 AM. |
#16 |
Roadtrip!
Sounds like a well optioned 67 3/4 ton truck. I would say not rare at all. No 327 4 bolt main blocks that i have ever seen, and a good share of them had a 4 bbl carb. It sounds like things have been done to it over the years, as it should either have a CST emblem on both doors or CUSTOM on both, but not one of each. I believe both fenders would also have a custom camper emblem on them too. The small back window was standard and no marker lights in 67 at all.
I would say with the truck being what it is and the frame being gone already, build what you want out of it. I wouldn't worry about a "full restoration" on this one. Does it still have the factory bucket seats in it?
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#17 | |
Every truck is "one of one" if you break the options down far enough. In the classic car world discussions about rarity are usually limited to model, Powertrain and (sometimes) interior/exterior color. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 06-24-2015 at 10:47 AM. |
#18 |
Not rare at all. I've seen plenty of 327s. None ever offered 4-bolt mains.
Tony Nicholas @ Midwest Metal Masters 1953 Chevy 3100 392 Hemi w/727 & 9” Ford 1985 Chevy C/10 6.0L 4L80 373 locker |
#19 |
Ok so I get the options make it one of a kind (like every other truck order witch seems to be a lot) the motor was rebuilt once that's how I know it's 4 bolt main LJ I'm basically 2nd owner my great uncle bought it in 68 used ( don't be fooled tho it was used cause it was driven as a advertisement by dealer ship then no longer need after next model came out ) if the 67 350 4 bolt main an LJ an shares block couldn't they have used one for there 327 for the dealership special?
#20 |
Evidently you cared not about the truck as a whole truck until after you junked the frame. Now either you thought better of it or someone told you that you scrapped a very valuable truck out for parts for another.
I would not worry about it at this point. Do what you want with the parts you pulled. I would also use this as the proverbial "lesson learned" and think before you jump. Or measure twice and cut once? No biggie. You didn't cut up the Mona Lisa by any means.
"Life is too short to drive a boring vehicle". Later, Wayne
#21 |
Well I got the truck years ago when I was 15 an didn't know that the motor was so uncommon being ( factory 327 4 bolt LJ) so I used my truck to hall salty dogs from the beach they rusted the bed and down on the frame ..then years later I wanted a 4x4 so I picked up a 69 k20 chassis , axles an an decent bed with title for $75 lol what a deal then I swapped the cab an front clip of the 67 an scrapted the rest ... The 67 frame would need some rust repair so I didn't think much of it till a day or two ago when I started researching motor an it seem my motor doesn't exist so I thought the whole vehicle might be worth saving as a number matching 100% factory resto ... Was just my thoughts so if not I have a wicked plan for my (pieced k20 CST )
#22 | ||
"I ain't nobody, dork."
There's "rare" and then there's sentimental value. Everyone wants their grandpa's truck to be rare and one of a kind. There were a lot of options for these trucks but not enough to make most of them "one of a kind".
Don't get hung up on the "numbers matching" thing... We're not talking Corvettes or Camaros. These trucks were utilitarian and engine combos were not performance driven nor were they rare. "Numbers Matching" for these trucks will not gain any value at all. Gary
#23 |
![]() Join Date: Oct 2011
I agree with most of the very knowledgeble guys here in the fact that there is not a case to be made here for any extended value due to rarity. Simply waaayyyy to many of these trucks made including that year and with the 327 option.
Try this out tho'...in the search window at the top of this page, type 327 and click '67-72 trucks option vs. 'the web'. That will give you an idea as to how many forum members have been exposed to the 327 angle with respect to the truck hobby through various years. All Good Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL 1966 Chevy 1/2 ton (Florida- Red/white) 1972 Chevy 1/2 ton (California- Blue/white) 2005 Chevy Silverado HD2500/Duramax 2000 Dodge Ram 1500 |
#24 |
I'm definitely in the "or what" category. These topics come up often. Everyone wants the truck in their garage to be a rare bird. The truck may not be rare and highly valuable, but it can be special to you, and that's what really matters. You'll never stumble upon the mythical Yenko or SS model C10 that never existed. The most rare versions of these trucks you'll most likely find will be low mileage examples.
#25 |
All right then ... : / this suck bleepen bleep I guess I'm gunna build my 4x4 with era correct parts of the best for what I want this will be my new build sheet
69 K20 chassis 6 inch lift Dana 44 closed knuckle arb air locker 4:56 ( I can all ready here the hate) Ho52 Detroit locked 4:57 Built supercharged 327 Sm420 / t221 RW CST interior w/custom design Custom 16.5 8 lug rally / beadlock rims 35x12.50r16.5 super swappers Dual aux tanks w/ rear suburban tank Turn signal style bumper with clear running light ( still keeping turn signal in grill) Gloss black trim / bumpers Inferno red paint There's still stuff I'm missing |
| Bookmarks |
