Old 06-24-2015, 01:56 AM   #1
wilkin250r
wilkin250r's Avatar
Re: Need a Fuel Tank Selector Valve
The single-wire approach is fairly simple in concept, but slightly more difficult to put into practice.
In theory, a simple buck/boost converter module to produce a -12V from a +12V power, then a relay to switch your single wire between +12V and -12V would essentially be the same as reversing polarity.
I can find pre-made DC-DC converter modules easily, many less than $5, and not much bigger than a relay. But to work, it either needs to offer full isolation, or it needs to specifically invert the source voltage. These aspects are simple enough design if I was doing the circuit from scratch, but very rare to find in a pre-made module. I've found a couple in the realm of $100, but nothing on the realm of $8.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
