Old 06-21-2015, 11:17 PM   #1
GMC-YA68
GMC-YA68's Avatar
Swiss cheese radio cut out - need ideas
The moron I bought my truck from had an 8 track in this thing, however it was cut long before he had it. I plan to run a CD player but should I just keep something like this same setup with the bezel? A radio delete falls thru this like its a black hole. A double DIN I don't think would fit between the AC and ash tray. I do not want to weld a new dash in at this time either....
Go ahead, start the chainsaw jokes.....lol
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 06-21-2015, 11:21 PM   #2
GMC-YA68
GMC-YA68's Avatar
Re: Swiss cheese radio cut out - need ideas
The "hole"
-Keegan-
Old 06-22-2015, 12:47 AM   #3
Warrens69GMC
Warrens69GMC's Avatar
Why not just weld a patch panel?
Old 06-22-2015, 01:08 AM   #4
Custom/Ten
Custom/Ten's Avatar
X2 I'm just curious what your reason is cause that things hacked up pretty bad to fix any other way. Could maybe improve the look a little by replacing the wood trim with a trim plate you make yourself from a patch panel but I don't really think you have any good options here due to the size of that hole. Maybe someone will have a better idea.
Custom/Ten is offline   Reply With Quote
Old 06-22-2015, 01:16 AM   #5
Custom/Ten
Custom/Ten's Avatar
Cool Re: Swiss cheese radio cut out - need ideas
Also feel I gotta mention calling the guy a moron for rockin the 8-track is not really a classy move bro. Couldn't stop myself. Good luck with your dash!
Old 06-22-2015, 11:50 AM   #6
Jonlopes
x3 you can either weld a patch panel or fab up something completely new. There is not much you can do with that hole otherwise.
1971 Cheyenne Big Block Longhorn
Jonlopes is offline   Reply With Quote
Old 06-22-2015, 01:13 PM   #7
57larry
have someone weld a new patch panel in for you
57larry is offline   Reply With Quote
Old 06-22-2015, 02:55 PM   #8
leftybass209
leftybass209's Avatar
I agree. The only correct option is a patch panel welded in. Anything else is sandwiched pieces of plastic or metal. If you thought the 8-track was a bad idea.....
leftybass209 is offline   Reply With Quote
Old 06-22-2015, 03:14 PM   #9
boraxman
Keepin an eye out
boraxman's Avatar
If all else fails I have a Realistic 8Track you can fill that hole with...I will even throw in a Eagles tape/
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 06-22-2015, 07:17 PM   #10
cigar-
cigar-'s Avatar
I'd scout around for an old really rusty truck and cut out the patch panel from a decent dash. If you can weld half way, set it in and let her rip. That way you go back to stock ('cept for ruining the paint) and can install a stock radio or one that fits into the stock opening.
That's what I'd do.......but I'm half crazy and the other half is stoopid!!
cigar- is offline   Reply With Quote
Old 06-22-2015, 07:26 PM   #11
old Chevy guy
old Chevy guy's Avatar
Get a piece of 1/8 '' aluminum like they make road signs out of ( you can pick it up all over the place on the sides of roads, lol) and make a panel you can mount a newer radio in for now and polish it up or paint it , just do a good job and let people think you did it on purpose. fix it right ,patch or change dash later when your ready.
old Chevy guy is offline   Reply With Quote
Old 06-22-2015, 08:04 PM   #12
In The Ten Ring
I have an 8-track in mine that my dad put in after he bought the truck new. If you'd like to call us that or anything like that to our faces, we could arrange a meeting. *You might want to put your affairs in order beforehand though.
The 8 track may have been put in when 8 tracks were the rage, such as in the case of my truck. My dad went to a junkyard and found an 8 track AM/FM radio and replaced the original AM radio sometime in the 70's or early 80's. I still have a bag full of 8 tracks and I had some cool tapes back when I drove the truck in the early 90's. I'm not huge on music anyway so putting in a CD player or something isn't high on my list. The dash was not cut as dad found a unit the same size as the AM radio it came with.
If I had a gaping hole like yours I'd hire someone to weld that back up to original size and then find like an original radio-looking MP3 player to go back. Granted I don't own an MP 3 player myself but that seems like a good option.
In The Ten Ring is offline   Reply With Quote
Old 06-22-2015, 09:17 PM   #13
GMC-YA68
GMC-YA68's Avatar
For the record I didn't say (or at least didn't mean it to say) he was a moron for the simple fact of having an 8 track. However he was a moron in general......
-Keegan-
Old 06-22-2015, 09:19 PM   #14
GMC-YA68
GMC-YA68's Avatar
That's what was it in it!!! And I have a whole case of tracks including the Eagles!
-Keegan-
Old 06-22-2015, 09:27 PM   #15
Tim Christian
Tim Christian's Avatar
http://www.keypartsonline.com/68-72-radio-repair-panel/
Tim Christian is offline   Reply With Quote
Old 06-22-2015, 11:39 PM   #16
Warrens69GMC
Originally Posted by Tim Christian View Post
OP needs one with a/c
Old 06-22-2015, 11:54 PM   #17
In The Ten Ring
Then why did you buy his truck?
Most of what bothers me about my truck's previous owner (dad) was what he didn't do.....he didn't have the rust properly fixed....he just sent it to a bondo happy guy that didn't know how to use masking tape during painting! LOL
Old 06-23-2015, 12:37 AM   #18
swamp rat
swamp rat's Avatar
Find a stock dash repair panel like they sell them here in the parts thread, if ya cut them right all the weld needed is pretty small 4 places onlyand not in the face of the radio panel, wide enough to be welded at the bezel and glove box.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-23-2015, 12:49 AM   #19
cherokeejohn
cherokeejohn's Avatar
General Motors ( AC Delco ) used a special radio size in alott of their vehicles from the mid 80s up to I know 2000. In the Crutchfield catalog it is called a size "CG". Only a few aftermarket company's make the upgraded models, also found on the Crutchfield website. Try measuring the size of your hole and if you will, post it up. I have a few old ones at my shop and I'll take a measurement tomorrow also. Maybe? cant hurt to check!
72 C/10, LWB, 5.7, Auto, with A/C
F.B.I = Full Blood Indian
Appalachia/Eastern Cherokee,"Tsalagi"
cherokeejohn is offline   Reply With Quote
Old 06-23-2015, 01:04 AM   #20
cherokeejohn
Other Ideas ??? Not to fond of the last pic, but You could use a diff material maybe
Old 06-24-2015, 04:08 PM   #21
Fitz
As an alternate try some 18 Ga cold rolled. A little shaping, a little welding and if that was done well, very little metal work before paint!
Fitz is offline   Reply With Quote
