06-23-2015, 12:12 AM | #1 |
Another d#$& lowering question !
I'm still working on my new crate engine install, almost done. And Gathering parts for a static suspension drop. I'm waiting to be able to still tow with my truck. So I'm going with hangers and shackles in the rear.
Now for my Question. Which is betterer drop spindles or drop lower control arms. Or drop springs. I don't think springs will do what I want alone. I intend on new drop shocks all the way around. Thanks Ken
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan |
06-23-2015, 12:19 AM | #2 |
Re: Another d#$& lowering question !
I am a big fan of spindles instead of control arms.
Spindles will theoretically correct roll center and minimize bump steer issues, whereas dropped lower arms cannot. Dropped control arms are better than radically cut coils, because they retain some decent suspension travel. But I would still pick spindles.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, boosted-LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
06-23-2015, 12:43 AM | #3 |
It followed me home?
spindles and cut a coil if needed
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
06-23-2015, 11:05 PM | #4 |
Spindles are what I had pretty much decided on. But having never owned a Chevy Trk. that has been lowered, I needed that second opinion. Thank you.
Ken
06-24-2015, 12:04 AM | #5 |
Spindles are your best option to lower the front.
06-24-2015, 01:00 AM | #6 |
Spindles
But how low are you wanting to drop all around?
2018 Audi S5- wife's ride 1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511 1981 Chevy Silverado- in pieces 1964 Chevy c10 2017 Jeep Wrangler JKU |
06-25-2015, 12:16 AM | #7 |
How low ? Taking in consideration I do tow with this truck, a motorcycle trailer and once in a while a car trailer. 3 to 4 in the front and what ever hangers and shackles will give me. If I have to remove the overload spring(helper). I will add air bags to take care of the loss in spring load rate.
Working with a C20 heavy duty suspension is new ground for me. So I'm moving forward slowly not wanting to do something to drastic that I won't like. Ken
06-25-2015, 12:37 AM | #8 |
Oh I didn't realize this was a C20. You'll probably wanna do spindles and springs in the front. Especially if you want 4".
06-25-2015, 11:24 AM | #9 |
sorry if I hijack, but going with JUST spindles, will the stock 15" wheels still fit?
06-25-2015, 11:27 AM | #10 |
My truck has stock 16 in wheels, but I considering changing to a set of later model aluminum 17 in wheels.
What is nice about this is I have the time mess with all these things. I do what my budget on such projects, being retired you have to watch how much you spend. So I always try to be smart about things. I picked up a daily driver which took some of the pressure off. Plus I have my bikes to ride. So if I don't feel like working on the truck I don't, I work on bikes. Which is my first love. KA
1985 IROC Z28 190HP TPI 305,700r4,T-tops,rear trac lock, Black on lite gray, 16in Z28 wheels 2007 Lexus ES350 (wifes) 1984 CJ7 with 1995 HO4.0L MPI, 2 1/2 OME YJ Lift “There is no limit to the amount of good you can do if you don't care who gets the credit.” ― Ronald Reagan Last edited by 1970pelle; 06-25-2015 at 11:35 AM. Reason: added a note. |
