Closed Thread
Old 06-25-2015, 02:51 PM   #2376
COBob'70 K-10
Re: What did you do to your truck today? Chapter II
I put mine up on Ebay for sale today:
http://www.ebay.com/itm/252007078680...84.m1555.l2649
COBob'70 K-10 is offline
Old 06-25-2015, 03:08 PM   #2377
powerhaulic
powerhaulic's Avatar
Got rid of the crappy braided wrap on all the hoses.
Replaced the copper and rubber fuel and vacuum lines with steel.
Replaced the Edelbrock carb with a 4175 Holley I just rebuilt.
And a new high vol water pump.
2011 Yukon XL Denali
1994 GMC Suburban 2500 454
1971 Cheyenne Super SB
1966 ElCamino
powerhaulic is offline
Old 06-25-2015, 10:00 PM   #2378
Saclandman
Saclandman's Avatar
New pipes.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Old 06-25-2015, 10:23 PM   #2379
66pnl
66pnl's Avatar
I like those valve covers, look like a short version of the old cal custom covers. Are those still available. (Yours I mean)
66pnl is offline
Old 06-26-2015, 07:08 AM   #2380
Baileyboro
Originally Posted by Metaldoc View Post
New coat of paint on all parts
Metaldoc! Is that "cast iron" header paint on the rams horns?
It looks great!
1970 Chevy C10 Longbed, Stepside (in resto)
1974 Alfa Romeo GTV2000 (next in line for resto)
1981 Mercedes-Benz 380SL (for sale)
1997 BMW Z3 1.9L (Twin 2's car)
2003 BMW 325i (Twin 1's car)(not nuf room for 2 more)
All of the above maintained by me!!
Baileyboro is offline
Old 06-26-2015, 09:41 AM   #2381
powerhaulic
Valve covers are still available
http://www.summitracing.com/parts/nal-474207/overview/
http://www.summitracing.com/parts/nal-474208/overview/
I like them beacuse of the production internal baffles, they wont suck oil out.
1966 ElCamino
Old 06-26-2015, 02:19 PM   #2382
Lees68GMC
Lees68GMC's Avatar
Big expense, $16.95 vinyl GMC letters on my old tail-gate
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline
Old 06-26-2015, 11:22 PM   #2383
9teen69
9teen69's Avatar
Painted my air cleaner. SEM black trim paint. One day I'll get around to painting my LH firewall back to Ochre
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 06-26-2015, 11:25 PM   #2384
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I like the affect 9teen69.
This week:
Thanks to Frank I located the rear window moldings. I'm still searching for great "paint separator" moldings, should anyone have a lead. Less window frame rubber, that's all that's needed for a complete exterior.
Polished the bed brace bolts up. I may have come to a nice system for prepping small parts. 1. Optional, depends on condition of paint: Soak in paint thinner for a bit, maybe half a day. 2. Soak in white vinegar for a day, two if you need it. 3. Polish them up (wire bushes) as you wash using baking soda & water. Maybe soak in soda solution afterwards, for a bit. 4. Rinse. 5. Soak them in WD-40 for a day. 6. Wipe them down. I'm no metal expert for certain, and I'm not sure WD-40 is the answer, but it seems oil for these small parts is a good thing.
Removed the paint from the differential. Paint removal wise, all that's left under the bed are the drive line and rear axle. Nice to find there's no rust. A little surface rust on the frame, and tight areas around the differential, but all comes off with ease using white vinegar.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline
Old 06-27-2015, 01:54 PM   #2385
midniteblues
midniteblues's Avatar
nate thanks for the tip. i'll have too find some of that acid.I reblasted them and ready too try again.
blasted the front bumper and front side of my caps(backs are allready done).
bumper had alot of stone chip pits in it but its in awesome shape for a oe peice.
so i put a few coats of 2k high build over the epoxy.
the caps got the same treatment these will end up being painted the same design as a 68 cap but with the the argent silver being 526 white and the black being 503 green.
just for a differnt look.
i'll still have a set of nice oe 67 caps it'll be cool too change them up every now and then
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 06-28-2015, 07:37 PM   #2386
9teen69
9teen69's Avatar
Restored the breather, clamps and replaced the hose on my aircleaner.
9teen69 is offline
Old 06-28-2015, 07:49 PM   #2387
9teen69
9teen69's Avatar
Started cleaning my RH front end. Getting ready for new rotors, caliper and brake lines next week. Has to be 5lbs lighter.
Shouldn't have cleaned it up now I notice my balljoints are hammered. As bad as my ball joints are I'm surprised my truck drives so well.
A bit better than the LH now.
9teen69 is offline
Old 06-28-2015, 10:16 PM   #2388
bigorange1970
bigorange1970's Avatar
Put on new seat covers... tightened up exhaust manifold bolts and drove her!!
bigorange1970 is offline
Old 06-28-2015, 11:46 PM   #2389
Jobe72
Jobe72's Avatar
Towed my 72 200 miles home after the engine seized up while I was visiting my dad for Father's day last sunday. Now to pull it and figure out what happened.
1972 GMC Sierra LWB (Aquafresh)
1962 Cadillac Convertible
1962 Cadillac Sedan project
Jobe72 is offline
Old 06-29-2015, 01:19 AM   #2390
71CHEVYSHORTBED402
Beautiful truck. What did the bed come off of?
Tony
Old 06-29-2015, 02:17 AM   #2391
64chevtruck
Finished my exhaust , Installed a Flamethrower, Installed some bullets, Completed my quest for fire.
Heres a link to the flames,
https://youtu.be/LTNf5-nEjbE
I should have panned out with the camera more, some of the flames went out like 5 feet and offscreen,
Have a good week,
64 C10 Fleetside LB 4 Sp/292 Build http://67-72chevytrucks.com/vboard/s...d.php?t=602438
70 GMC 1500 Fleetside LB 3OT/350 Build http://67-72chevytrucks.com/vboard/s...83#post6767983
76 GMC CCLB Dually Build http://67-72chevytrucks.com/vboard/s...d.php?t=691612
79 GMC 3500 Fleetside LB 454/400
90 Suburban Silverado 4x4 350/700R4
97 1500 Cheyenne Short Fleet 350/5sp
64chevtruck is offline
Old 06-29-2015, 10:04 AM   #2392
bigorange1970
Came off a 1990 stepside chevy
Old 06-29-2015, 11:57 AM   #2393
DarkFlounder
Started media-blasting my bed parts. Using a $50 HFT blaster. Once I resolved the humidity issues (3 air filters in series does well enough), did a pretty good job. Would be better with a larger air compressor, but I can't run anything bigger (no 220v). So, frequent breaks so the compressor can catch up.
But it's doing great at getting rid of the surface rust. So, I got that going for me, which is nice.
72 K2500 Sierra Longbed Wideside 350/TH350/NP205
66 Plymouth Barracuda 225 Slant6
DarkFlounder is offline
Old 06-29-2015, 03:42 PM   #2394
Metaldoc
Metaldoc's Avatar
It looks great!
Yes it's cast blast exhaust paint.
Derek.
Metaldoc is offline
Old 06-29-2015, 03:52 PM   #2395
Davidf
Over the weekend, I replaced the water pump (made little difference, must be the radiator needs replacing...temps just a bit too high. I was thinking the impeller may have corrosion and causing cavitation. A new water pump is peace of mind anyway). I also rebuilt the door hinges on the driver door. Plastic bushing were worn totally out. hinges now have virtually zero play. But, I am having trouble adjusting door strike of all things. before, door closed relatively easy...especially if I lift door slightly when closing. Now, it takes a slam and sometime bangs hard. May be that latch is wearing out. I have the strike adjusted per service manual. Next is to play with strike position to see result. Just too damn hot and tired to figure it out on Sunday. Getting those hinges off and then readjusting the door is a PITA.
Davidf is offline
Old 06-29-2015, 10:17 PM   #2396
9teen69
9teen69's Avatar
64chevtruck - Those flames are crazy...you're going to scare a lot of Prius owners
Davef- Sunday was hot and very humid, 4 hrs in the garage and I was soaking wet and beat.
9teen69 is offline
Old 06-29-2015, 10:56 PM   #2397
In The Ten Ring
Today, RESTED, because yesterday, I drove down to NC to meet Panel Deland, and I got to sit in his panel! :-) :-)
He also hit me with some great advice about what I have to look forward to and he gave me a cowl in exchange for helping him put his hood back on.
I then went to see a friend and so, I didn't leave until midnight. I slept about an hour at a VA rest stop and got home at 4 AM. I was so tired I slept till 6 AM in the car, in the driveway!
In The Ten Ring is offline
Old 06-30-2015, 12:25 AM   #2398
stepsider
stepsider's Avatar
Took the truck for a ride today, Took my garmin with me. I wanted to check my speedometer. At the lower speeds 1 to 2 miles off. At 65 only 1 mile off, what a surprise.
stepsider is offline
Old 06-30-2015, 03:44 PM   #2399
hamjet
hamjet's Avatar
I got the 348 dropped in and bolted to the transmission. Motor mounts don't work, hitting the exhaust manifold. don't know if bb mounts will work, hate to order them, wait for them to get here and find out they don't work either. I'm going to think on this one, trial and error. Whats a fool to do!
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 06-30-2015, 06:13 PM   #2400
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
I'm back from burying Mom , I went by the paint jail to - day to see if Paco found my gone missing original gas cap ~ he was out chasing parts so his Wife took a note reminding him I'll never stop asking for this hard to find part .
Anyone here who has the correct original painted cap with stamped in ring , I'll buy it , rusty and cruddy , I don't care .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Closed Thread
