#26 | ||
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
Re: Eaton HO-52, Need a little advice
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#27 |
Vintage 4x4s
If you have a trailer like this with no gears but good bearings and seals, turning the cover upside down is a good idea, you can get just enough gear lube in there to always keep lube on the bearings. I've done it and it works good.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
#28 | |
![]() Join Date: Apr 2012
Good idea....probably the only kind you have, right?!!
1971 C/10 SWB, 15x8 Rallys, 4.5" X 7" static drop, C-notched, 350/350, 3.73 Posi. .........A 383 and Gear Vendors are on my bucket list. 1972 GMC 4X4 K1500 Survivor - Sold No matter what problems life throws at you, your time on Earth can be incredibly fulfilling and rewarding.....if you just lower your expectations. -Phil Dunphy |
#29 |
Vintage 4x4s
Yes, I've been fortunate all mine have had good bearings and seals so far. 2 of these are Dana 60's though.
#30 | |
#31 |
It took longer than planned, but I finally got everything put together.
I used new seals, repacked the bearings, and made my own gaskets with some "Right Stuff". I let the gaskets dry for 24 hours before adding any gear oil. With the 3rd member and axles out and the cover installed purposely upside down, it took almost 9 quarts of gear oil! Not one drop so far. The vent was totally missing, so I drilled out a little check valve I found at the parts store and fabricated my own vent. Last thing I did was replace the shocks that were completely worthless. Luckily I had some good stock style ones I saved from before my truck was lowered. I really appreciate all the advice I got from everybody here. I am really a hands on kind of learner, so I can read it a hundred times, but until I do it for the first time I feel lost. It was a good experience digging into this. Now it's time to use the trailer for what I wanted it for and plan some dirt bike trips with the fam-jam!
#32 |
Took the trailer on a 300 mile round trip dirt bike trip with the boy. Not one problem, barely noticed I was pulling it behind me!
Had a blast and can't wait to do it again. Really nice to have all that extra space.
#33 |
That's very good to hear. Time with the kids is priceless. Having a cool trailer definitely doesn't hurt.
