GM ONLY BABY!!!
Will 73 spindles fit a 72?
Will a set of 73 Spindles fit a 72 GMC that already has disc brakes? I heard that there is a diffrence in the lower ball joint is this true? Can I change the ball joints and make them work? Thanks, you guys are kewl!!!
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
belly dragger
Change the upper ball joint and the outer tie rod end to 73 and up and they work just fine.
how about a 70 with drums i know illhave to change the brake but thats what i want to do i just want to know if i can go with all 73 parts
belly dragger
Yup just buy all 73 and up parts they're cheap too.
You also need a Tie Rod adjusting sleve CPP sell's it. The outer tie rod for a 73 is bigger than the 72 inner. Other than that it will work awesome. I did it. Also you can use 73-87 flex lines too. Oh and you use a 67-70 outer tie rod on the inner. No that's not a TyPO. I am serious.
Any other questions just ask.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
73-87 are they all the same? I have spindles, calipers, and everything off a 78. Would it all fit if I used the newer upper & lower ball joints, and just change the outer tie rod ends?
My truck is a 1969 w/drums. thanks |
My truck is a 70 and I used the spindles and calipers Etc.. off a 78 just change out the upper and lower ball joint. I used the tie rods and centerlink off of the 78 it fits on the stering box perfectly. Remember to install a proportioning valve I used one off a 71 or 72.
