Old 06-26-2015, 03:28 PM   #1
Zach079xxx
Zach079xxx's Avatar
Air Conditioner help! 85 C10
Hey guys this Virginia heat is getting a little extreme. I bought my truck about a year ago, I wanna say the AC worked back then. But for the last few months it hasn't worked. I replaced the blower motor, thinking maybe it was weak, which anyways it was probably time for a new one. I also replaced the vacuum switch behind the controls. Then today I popped the hood and with the AC running I looked at the compressor and saw a caulk or putty kinda deal, I felt air shooting out of it, shown in picture! I pulled it off and it really started coming out. Why would air be coming out of it? What can I do? Can I putty and JB Weld it back up?
I know I have a vacuum leak inside the cab also. I was told with controls on Max AC air should NOT come out of the floor, which it does I'm stumped on it. Also heat blows maybe atleast twice as hard as cold. Maybe someone has had this problem before, or similar. I AM STUMPED lol!
Zach079xxx is offline   Reply With Quote
Old 06-26-2015, 03:56 PM   #2
RUN GMC
RUN GMC's Avatar
Re: Air Conditioner help! 85 C10
Your leak is inside there your evaporator....replace it........
RUN GMC is offline   Reply With Quote
Old 06-26-2015, 04:06 PM   #3
Zach079xxx
Zach079xxx's Avatar
How bad is it to replace it? What should I watch for? Is this why my AC isn't blowing cold?
Old 06-26-2015, 04:34 PM   #4
hatzie
Moderator
hatzie's Avatar
With the blower on or off?
I assume it's shooting out with the blower on because the airbox is leaking around the AC pipe. That's usually because the black butyl and cork sealer has gotten brittle and not as sticky from age.
You'll need some "cork insulation tape". The old timers called it dum dum tape.
Wrap several layers around the evaporator pipes and into and over the hole in the fiberglass evaporator box. That'll block the leaking fan air and force it into the ducts in the cab rather than exhausting it into the engine bay.
If the evaporator was leaking then shortly, in a few seconds, the Freon would discharge and compressor clutch would disengage. Then the leak would stop because there's no more freon to leak.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 06-26-2015, 04:44 PM   #5
Zach079xxx
Zach079xxx's Avatar
My compressor never disengages unless I switch it off. I'll seal it up and see how it goes. Thanks!
Old 06-26-2015, 06:11 PM   #6
Dead Parrot
check out the following thread: http://67-72chevytrucks.com/vboard/s...d.php?t=460942
A lack of vacuum or a broken plastic thing that is shown in post #5 of the other thread will result in the blown air coming out of all of the outlets. In my case, it was a broken white plastic thing.
If your heat/cold flapper is leaking or out of adjustment, the heater core might be competing with the A/C. A quick test for that is run the A/C with a cold engine. If the air starts off cold and becomes less cold as the engine temp warms, suspect the heat/cold flapper.
Dead Parrot is offline   Reply With Quote
Old 06-26-2015, 07:12 PM   #7
Zach079xxx
Zach079xxx's Avatar
I pulled the vaccum line off under the dash and it was sucking air. The garage I deal with has been shabby lately and I might get someone else to see if it needs to be charged. It's simply just not cold, it's cool but not cold. And I'll try the start method you mentioned Dead Parrot. Thanks everyone that's mentioned something!
Old 06-27-2015, 08:42 AM   #8
homemade87
Zach , I used and electrical puddy use on houses to seal the top of the wire entering the electrical box outside . I picked up mine at the local building supply . This worked great on the a/c box . Its a soft puddy that's made to withstand the elements . It comes in a small brick wrapped in plastic . Dont use anything that permanent . Pain when it comes to service .
Also I agree about the broken plastic thing( need to check it out ) . If you have air coming from multi vents you need to correct this first before anything . Need to find out why .
homemade87 is offline   Reply With Quote
Old 06-27-2015, 11:42 AM   #9
Zach079xxx
Zach079xxx's Avatar
Thanks! I got them sealed up and will be moving onto the vents sometime soon!
Old 06-30-2015, 09:09 PM   #10
Axle
Axle's Avatar
While you are doing that, remove the blower resistor and look at the evaporator and see if its coat a blanket of dust and debris on it, if so, you might get lucky and get it mostly cleaned up with a hose taped to your vacuum that you can fit through the blower resistor hole if you don't want to take anything apart. yet. =-)
ALex.
Axle is offline   Reply With Quote
Old 07-01-2015, 12:19 AM   #11
Zach079xxx
Zach079xxx's Avatar
Thanks I'll try that
ALex.
