06-25-2015, 03:51 PM | #1 |
Air cleaner Help
I recently purchased a 1972 C30 RV that has original big block 402 motor. The air cleaner had been cut off at the snout after the Thermac control. I'm not sure it is original to the truck, always figured it was. I decided to strip and paint an air cleaner from a 350 small block. I then noticed that the one from the rv on the right side of picture has a much wider snout. I thought that V8 big and small block air cleaners were the same??? If so what could the one on the right be from if it isn't original. Notice the thermostatic vacuum switch is on left on one and right on the other.
06-25-2015, 04:06 PM | #2 |
Re: Air cleaner Help
The one on the right looks like it had a fresh air tube hooked to it. The one on the left is too restrictive for a big block. It is even too restrictive for a 350 but they came out that way.
06-25-2015, 04:13 PM | #3 |
Moderator
The left one is original to our trucks, the one on the right is not. Big and small block air cleaners were the same on our trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
06-25-2015, 09:05 PM | #4 |
either one, but I would cut the end off the 350 one to allow more air and cut the end off the other one to eliminate the holes in the end
06-26-2015, 01:12 AM | #5 |
why chop it up? why not put it aside and a get an aftermarket aircleaner. best of both worlds, win win all around
06-26-2015, 11:08 AM | #6 |
The one on the right would probably have come from a class C motorhome in the later 70s or 80s they ran the fresh air tube to the radiator support.
06-26-2015, 01:58 PM | #7 |
Spot on! While I was looking for a factory air cleaner assembly in the junkyard I ran across a couple motor homes that had these style air cleaners. The lid is correct, but as you mentioned, the base and snorkel assembly are different. The snorkel size and positioning reminds me of a 70's Pontiac style base as well, which had one or two snorkels depending on application.
06-26-2015, 02:05 PM | #8 |
Actually if the plastic clip was still intact you could make a vintage cold air intake like the 81- 87 and above trucks had.
06-26-2015, 03:35 PM | #9 | |
06-26-2015, 03:41 PM | #10 |
That is a cool rig. I have seen a few and tempted to buy one but have no time to use it. That looks to be in nice shape. Possibly you could post more pics of it.
