#51 |
Re: Finally Started! 75' Crew
Ok as stated here are the interior photos so far.
![]() ![]() ![]() ![]() ![]() Still working on figuring out how to restore the door panels to the natural beauty. I have not once ran across the trim panels that looked the same as these. Here is what the driver door looks like.... its bad... ![]() And here is the back passenger side door.... Notice the burlwood and the nice silverado aluminum accenting. ![]() ![]() Any ideas? |
#52 |
Man that interior is awesome!
Current Build 89 s10 ecsb 2wd 4.3/700r4 50k OG Miles Instagram- shaggin_s10 '86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt (Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD |
#53 |
Well.... for something that has not once been restored.... i guess you could say it is pretty good. I am wanting to build a center console for it and actually buy new carpet. Of course along the way do a restoration but it costs a lot of that green stuff that I dont have a lot of.... ha. Too many projects not enough time or money.
#54 |
On your woodgrain question. I can see 2 options. First would be to dig up some 3M vinyl. Or dip them https://www.youtube.com/watch?v=qDfyq_o-3Nw
72 GMC C2500 402/Th400 first truck (still have) 77 GMC C3500 CC dually Sold ![]() 70 C50 dump truck "Rusty" 87 K10 Suburban Sold 93 K2500 xcab 6.5TD 96 GMC K2500 Suburban 6.5 TD |
#55 | |
#56 |
Sweet! I like that hood!
#57 |
#58 |
Well I am sure you will find one!
#59 |
#60 |
Tint looks good to me!
#61 |
#62 |
Park 'er in the sun the heat will get the little bubbles out.
#63 |
I like your avatar (fallout) truck looks good, that cowl induction hood looks a little bent though lol.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
#64 |
#65 |
Yeah.... such a fun game. Thank you by the way and yeah the fiberglass hood is bent pretty good. Im waiting to get it replaced. Dont know what i would do with the one on it though.
#66 |
#67 |
Finally another update. Got the hood supported with some pieces of thin gauge steel, got the passenger mirror relocated to match the driver side and got a center console for it. As for the mirrors, turns out they were the cheapos and I will be putting on better ones in the near future. They would never stay tight so when i went to tighten the driver side, it just got worse. The passenger side was not installed correctly so the vent window wouldnt open. Upon relocating it the glass broke. Luckily ive got a different mirror set on my parts truck.
Now on to the good stuff.... Scored a blazer center console to match for only $40! Took a little cleaning but now its in. Looks like i will be sticking to as close to original as possible on the interior. Maybe with a few creature comforts ie 12 volt sockets in the console, a better stereo setup, and i might try and have the buckets bolstered a little bit. Also I plan on cleaning up the dash and covering it with a fabric of some sort. Not quite sure on that route though. Enough blabbering and on to the pictures of the console setup! ![]() ![]() ![]() ![]() Now heres a little something i thought up with the rims. I wasnt a huge fan of what is currently on the truck so i did a test fit with a modern hubcap. I would like to try a 90's model black one to decide on just what I want but what I did try I really like! What do you think??? Here is what I had originally ![]() ![]() And here is what I came up with. I think black with a gold chevy logo would look better.... ![]() ![]() ![]() |
#68 |
Second Chance Program
I like it! And I like the console, tint, and hood! Also I just realized our trucks are just about twins!
[IMG] ![]()
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
#69 |
#70 |
#71 |
Personally I like the silver one better.
#72 |
If not for my current truck with no CB in it, Id be convinced GM sold those truck with holes predrilled for the CB mount. Never seen one mounted else where haha
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims. |
#73 |
Got a little done today.... fixed my temperature gauge and messed with my sticky throttle. Need to shorten the cable a few inches so it doesnt jump off the line. And with any luck ill be getting a newer dash this weekend, or in the near future!
#74 |
Been starting to look into redoing the dash. Got as far as looking around for the right vinyl or fabric, then started trying to do prep work. The old material was SO bad that if you put any pressure ANYWHERE it would crack. So i decided to start removing everything down to bare metal. Cant decide which route i want to take on it. I can either find a new dash, or fiberglass what ive got and cover with fabric. Either way its in the process. Other than that, I got bored recently so i started making my own overhead console. Got some pics of the progress. My plan is to use the taller portion for switches for accessories, and install two sets of adjustable map lights for the front and rear seats. Also i will be putting on courtesy lamps in the middle for when the doors are open. I plan on doing the majority of it in the same material i put on the dash, then the center main portions will be the same wood grain as the door panels and dash panel. I made it 40" long and 3" tall at the short bit and 6" tall where it will drop down for the switches.
![]() ![]() ![]() ![]() Here are the map lights I plan on using. Or something along those lines anyhow..... ![]() |
#75 |
