Old 05-23-2015, 09:02 AM   #676
Rochlow
Re: Project Roxy
It's at ride height and set a 6 degrees down. When I first installed the dropmember the oil pan hit the rack, so Nate made some engine plates to raise the motor 1/2". There is about 1/16th" between them now. I thought about beating the area of the cab with a hammer to make room. But not sure if that's the best option.
Rochlow is offline   Reply With Quote
Old 05-27-2015, 09:21 AM   #677
Rochlow
Re: Project Roxy
Originally Posted by Hart_Rod View Post
Roch - how high was the spacer that you put under the carrier bearing? I had to install a 2 7/8" one in order to get my angles close.
I added a 3" spacer under the carrier bearing.
I sent a bunch of emails to Nate regarding the issue. However, with the holiday weekend and new stuff he's building I figured he is busy.
My fix for the steering rack/motor issues is that I ordered some Steeda offset bushings .25 and .40. I'm hoping to lower the rack .40 and the motor 1/4" to solve my issue of the trans yoke hitting the cab.
///Relaxed Atmosphere
Old 06-25-2015, 10:38 PM   #678
Rochlow
Re: Project Roxy
Does anyone see anything wrong with this. Not sure with the lines above the m/c outlet if that would cause no pedal pressure
Old 06-28-2015, 10:04 AM   #679
Hart_Rod
Hart_Rod's Avatar
Re: Project Roxy
I would change both of those lines. The line on the left looks like it's crimped really bad by the fitting. I would make sure they both go straight down. If you are going to loop them, loop them on a horizontal plain, not a vertical one like they are now. Here's what mine look like.
Hart_Rod is offline   Reply With Quote
Old 06-28-2015, 10:42 AM   #680
jlsanborn
jlsanborn's Avatar
Re: Project Roxy
I don't see anything that would prevent pedal pressure there but the line on the left does looked kinked a bit.
'77 K30 3+3 - "The Crummy"
http://67-72chevytrucks.com/vboard/s...d.php?t=640134
'67 C10 L/SWB - Soon to be daily driver!
http://67-72chevytrucks.com/vboard/s...d.php?t=471776
jlsanborn is offline   Reply With Quote
Old 06-28-2015, 07:52 PM   #681
Rochlow
Re: Project Roxy
Thanks for the advice guys
Old 06-28-2015, 08:44 PM   #682
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Project Roxy
With the way your prop valve is mounted,... Two "U-shaped" bends would work perfectly,... From the M/C.
Keith
Convert to disc brakes.
Old 06-28-2015, 10:39 PM   #683
Rochlow
Re: Project Roxy
The slosh tubs make it difficult to make the lines come out very far.
I adjusted the length of the parking brake cable and let the rear parking brake adjust itself by setting and releasing the brake. My wife helped me bleed the brakes and they seem to be ok now.
Old 09-22-2015, 11:46 AM   #684
gringoloco
A guy with a truck
gringoloco's Avatar
Re: Project Roxy
What's happening lately with Roxy? All your pics are gone...
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 02-10-2016, 08:26 PM   #685
Rochlow
Re: Project Roxy
I deleted them for whatever reason I was thinking at the time. I should update a few.
Old 02-10-2016, 08:36 PM   #686
Rochlow
Re: Project Roxy
Old 02-10-2016, 08:37 PM   #687
Rochlow
Re: Project Roxy
Old 02-10-2016, 08:38 PM   #688
Rochlow
Re: Project Roxy
Old 02-10-2016, 08:39 PM   #689
Rochlow
Re: Project Roxy
Old 02-10-2016, 08:40 PM   #690
lolife99
lolife99's Avatar
Re: Project Roxy
looks good!!!^^^
Keith
Old 02-10-2016, 10:22 PM   #691
Bennett68C10
Bennett68C10's Avatar
Re: Project Roxy
Roxy looks great!
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 02-10-2016, 11:39 PM   #692
jeh
jeh's Avatar
Re: Project Roxy
Killer truck, I've been looking through a lot of builds on here this winter and can't believe all of them I've missed out on!!!
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 02-11-2016, 12:50 PM   #693
jlsanborn
jlsanborn's Avatar
Re: Project Roxy
Where'd you get the speaker pods? Likey?
Old 02-11-2016, 01:50 PM   #694
Rochlow
Re: Project Roxy
I made them.
Old 02-13-2016, 08:06 PM   #695
Rochlow
Re: Project Roxy
Working on the bed..
Old 02-13-2016, 08:14 PM   #696
jeh
jeh's Avatar
Re: Project Roxy
Nice work!!!
Jason
'10 Ford F 350
'13 Ford RAPTOR 6.2
Old 02-13-2016, 10:36 PM   #697
preacher anthony
Re: Project Roxy
What color is truck. Maker of paint?
preacher anthony is offline   Reply With Quote
Old 02-13-2016, 11:02 PM   #698
Rochlow
Re: Project Roxy
Maroon poly. Basf/RM
Old 02-14-2016, 12:01 AM   #699
preacher anthony
Re: Project Roxy
Okay, thanks. I want to paint mine some shade of burgundy .
Old 02-14-2016, 10:23 AM   #700
Rochlow
Re: Project Roxy
I had sticker shock when I bought it.. The base was $1400 a gallon and the clear was $400 (needed 2 gallons of clear). All said in done, I had roughly $2500 in materials alone.
