AC ashtray paint question
I need verification of paint color on the AC ashtray bracket, does anyone know what color the mounting bracket is supposed to be.
Re: AC ashtray paint question
60-66 Nut
On mine, the formed mounting bracket looks like it was originally fawn. The bracket that the ashtray actually slides on, I had zinc plated.
mine looks like its never been painted. so I would get it zinc plated as well.
Hand Made Factory reproduction A/C vents text or call 602-361-6421 Website for A/C vents https://coolc10.com/ |
![]() Join Date: Feb 2014
on mine the bracket the ash tray slides on was plated but was the ash tray it self fawn
![]() Join Date: Jan 2001
It looks to me like it was supposed to be a trim black color and that is what I plan to paint it.
I also am using the tray off a 63 or 64 Impala ac car and it used a plastic filler piece mount between the tray and the bottom of dash and it was painted the dash color same as the tray front.
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 factory #'s V8 stepside project '72 Cheyenne K20 50k original '72 CST Blazer K5 owned 30+yrs '73 Sierra swb 4x4 '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
Mine is from an Imapla also. The plastic piece is molded in black on mine.
![]() ![]() Join Date: Apr 2012
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
so awesome thanks for showing us
Wow, very nice , I luv NOS, thx guys
#12 | |
Me to !
i would need to have all 3 of my platers to recreate this one!!!
Im doing my own zink phosphate its called Parkerizing and bright zink plating on the other pieces now the problem taking it apart and putting it back together
#15 |
Found fawn paint on the mounting bracket.
Posted via Mobile Device |
#16 |
#17 |
Curious if the dash was painted with the bracket in place ? Do you remember ?. Being painted like that may lead to whether the factory installed air did that or if a dealer would even bother painting the ash tray ??
#18 |
I would have to believe LT1 that your ashtray assembly was line painted laying on the floor of cab for factory install. Looks as though screws were not installed yet when 65 interior color was shot in paint line. I have one of my 3 1966 factory air trucks that appear to have been assembly line installed air. Thus the dash air balls are mounted in a factory painted dark fawn housing. This truck also has the deeper factory air x brace still riveted to the support not bolted with a spacer as kit instructions showed. The ash tray was missing on this truck so can't identify over spray but the lower dash shows no trace it was mounted when dash was line painted. Great info as I am in the same area of restoration now.
#19 |
Good point Jon as this tray may also be a dealer factory ac kit and the installer put the unfinished tray together and shot the dash color on it then installed it. Mark
#20 |
I can't remember if this was the ashtray from my truck. This project has carried on for so many years now that I cant recall.
#21 |
![]() Join Date: Oct 2013
Just adding a little more information on ash tray coating and paint. This mounting bracket was painted fawn like Captainfabs and LT1s. From a 65', that was built in Tulleytown, NY ( something like that- at least in NY).
Also, the dash under side where it is mounted, is fawn painted. So not installed when painted. This is just data, do not know how or when it was painted. Just strange some parts painted and other not. Maybe suggests that certain parts of ash tray where produced and coated separately, at different times. Assembly of ash tray may have involved multiple steps leading to an installed ash tray?? Les Last edited by aotte1; 08-27-2017 at 01:18 AM. |
#22 |
Another photo, doing Ipad,
#23 |
Just checked the second AC ash tray and it is painted the same as first one above. Again this is data, what information it supports to be determined hopefully in the future.
Les |
#24 |
I did finish mine.
#25 |
what color did you use to replicate the fawn?
