Old 02-13-2004, 10:33 AM   #1
jared stewart
Silverado Stew
jared stewart's Avatar
Question Need Opinions (Advice)
I have a '79 350 that blew a gasket and sucked all my antifreeze into the oil pan. Now I have a friggin' chocolate milkshake to deal with. My questions is: Should I run something like auto transmission fluid through the motor to help clean it out, or just change the oil and run it for a little bit, then change it again?
- 1997 3/4 Ton Ext. Cab LB 4x4 6.5L Diesel
- 1979 3/4 Ton Longbed 4x4 "Farm Truck"
- 1984 1/2 Ton w/ '99 Vortec 350/700R4 2x4 FOR SALE
jared stewart is offline   Reply With Quote
Old 02-13-2004, 10:54 AM   #2
swervin ervin
You get what you pay for
swervin ervin's Avatar
I would remove the oil pan and clean it out. Then put in fresh oil and filter. Start it up and run it til it gets warm. Drain it again and new oil and filter. Run it for 500 miles or so, and change the oil and filter again.
I suggest doing this pretty quick before rust starts to form on the cylinder walls, which only takes a day of so.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 02-13-2004, 08:18 PM   #3
Tom
driving is in my blood
Tom's Avatar
Id just drain the pan for a couple hours, run a few quarts of good oil threw it for a minute or two, then drain, refill and dont worry about it.
