Old 07-01-2015, 05:36 PM   #1
bpmack16
Recommendations for tubular control arms.
I want to go tubular control arms on my 72 c10. I love the Hotchkiss products but can't depend the cash at the moment what's my next best bet? Any of them center the tire in the wheel well like the Hotchkiss stuff.
bpmack16 is offline   Reply With Quote
Old 07-01-2015, 06:05 PM   #2
SCOTI
SCOTI's Avatar
Re: Recommendations for tubular control arms.
Porterbuilt arms would be my next choice after Hotchkis.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-01-2015, 06:24 PM   #3
bpmack16
Any more options so I have something to resurch tonight?
Old 07-01-2015, 06:43 PM   #4
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If tight on cash, why change arms? There is nothing wrong with them. Tubular arms are great if you are going with air bags, coil overs or just have money to burn.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 07-01-2015, 09:13 PM   #5
Pro Performance
Pro Performance's Avatar
We really like the Porterbuilt arms and our customers have been very happy with them. What are your plans with the suspension? The Porterbuilt arms offer different variations, depending on what your plans are for the truck.
Pro Performance is offline   Reply With Quote
Old 07-02-2015, 08:35 AM   #6
bpmack16
At this point my truck is making some weird noises when turning. Only when the brakes are hot. If I push on the brakes the noise goes away. The guys at properformance where I got the brake kiy have been great but unable to figure out what the problem is. I have taken everything in the front end off multiple times and see no problems so **** it I am changing everything. The noise is killing me.
Old 07-02-2015, 10:23 AM   #7
KEWLKATDADY
man, replacing parts without diagnosis is much more expensive than properly diagnosing the problem.
just my $.02
1967 C10 custom
KEWLKATDADY is offline   Reply With Quote
Old 07-02-2015, 12:06 PM   #8
chevy_mike
chevy_mike's Avatar
So you are having an issue with a noise, that only happens when the brakes are hot and if you are turning but goes away if you push on the brakes. To solve this you want to replace all the arms.... That seems a little extreme, kind of like saying my engine stalls and to fix it you replace the entire engine.
What type of noise are you having? What type of brakes are they? Do you get any noise when they are cold? My first guess is it is pad knock back and the noise is the pads rattling. Could be as simple as the wheel bearing is too loose and allowing the rotor to move in and out, pushing the pads back in. It goes away when you hit the brakes because you remove all the slop that occurred when the pads pushed back.
Old 11-23-2015, 04:27 PM   #9
bpmack16
The noise I am having is like a grinding, humming noise during Turing in either direction when brakes are hot. I have the pro performance 14" bbk from bear. No noise when they are cold. Any more help would be great this is the 3rd full week the truck has been in the shop and funds are tight. HELP
Old 11-23-2015, 04:58 PM   #10
SCOTI
SCOTI's Avatar
Has the shop verified the front end is solid (nothing loose/worn/etc)?
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-23-2015, 05:16 PM   #11
bpmack16
[QUOTE=SCOTI;7386264]Has the shop verified the front end is solid (nothing loose/worn/etc)?[/QUOt
Are you referring to the front cross member and radiator support?
Old 11-23-2015, 05:44 PM   #12
SCOTI
SCOTI's Avatar
Front x-member & anything suspension related that ties into it.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 11-23-2015, 06:35 PM   #13
bpmack16
Yes all of that looks good. I have new shocks and POL shock relocation brackets welded to frame. The x member is good as well. Like I said the noise goes away when you apply the brakes and only during turning.
Old 11-23-2015, 06:44 PM   #14
Pro Performance
I know we have been working with you to resolve this issue that we can't seem to trace down to one item. I know we looked for any witness marks or points of things wearing or grinding and couldn't find anything. The new kit we have sent your way should get you back on track. Please do keep me posted once it is installed and back on the road.
- Travis
Old 11-23-2015, 07:04 PM   #15
bpmack16
- Travis
Once again thank you for all your great service and availability during this matter. I will defiantly let you know once I get the call from the shop. I am just trying to cover all my bases incase. Thanks again
Old 11-24-2015, 04:46 AM   #16
BigDan3131
BigDan3131's Avatar
So did they pull apart the the brakes? It sounds like when some part gets that hot its growing causing an interference like there is the wrong shims in place. As far as the noise going away when you press on the pads, are there different compounds of pads for your system? They might be the wrong pad for your driving style or the pad itself has gone bad from warped rotors.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 11-24-2015, 07:58 AM   #17
bpmack16
Rotors are new and we changed the pads to see if that would help and it has not. The kit has been apart many times looking for ware marks or signs of rubbing. We can find no such issue.
Old 11-25-2015, 04:12 AM   #18
BigDan3131
BigDan3131's Avatar
Okay, that's that. Did they replace the bearings or at least clean and degrease them to check for bad spots? I had a grinding type noise and it was my bearings that were shot, they didn't have enough grease to keep them cool and got way to hot. When I turned the wheels it put extra strain against the bearings, especially the one in the rotor.
