06-30-2015, 05:15 PM | #1 |
front disc brake line
Is there a preformedbrake line for front disc brakes for my 65 Suburban? I made one from straight brake line using my original line as a template but it isn't against the crewmember like it should be. I know that disc brake line is smaller in diameter.
07-01-2015, 06:28 PM | #2 | |
Re: front disc brake line
Keep in mind... I also have CPP's master/booster/proportioning valve combo that these lines are designed to connect with. If your prop valve isn't attached to the master cyl, these lines will not fit without mods. Hope that helps.
* My 63 C10 SWB Fleetside (converted to BBW): http://67-72chevytrucks.com/vboard/s...58#post6851558 @johnny_lamebridge on Instagram |
07-01-2015, 10:21 PM | #3 |
My setup is from Master Power Brakes. I had to make the 2 lines going down from the m/c as well. I tried to upload pics of my lines but they won't go from my phone. I'll check online or with MPB to see what they have.
Thanks for the help |
