Dash Question
Does anyone know if I could use a dash pad from an '81-'87 K10 in my '75 K10 without any modification? The previous owner changed to the newer door panels and since I need to replace the dash pad I thought maybe I'd get the newer style as well if it fits without any modifications.
Thanks in advance for any help. |
Slots go on anything!
Re: Dash Question
Yes. It will work.
1974 Jimmy- 5.3/4L80e/NP241 |
Re: Dash Question
the newer dash cover\s your vin tag and the far left hold down clip cant be used (vin tag area)
That said, it will work |
Re: Dash Question
Will the 75 even have a dash VIN tag? I thought they started in like 78 or so.
The dashboard mounts up fine, except for the left hold-down clip as 2 Far Gone mentioned already. BUT... The gauge cluster and bezel mount differently, also. I know that using a newer bezel with the older dashpad looks terrible, it leaves and unsightly gap. In mounts up and functions okay, it's just ugly. I believe the direction you are planning, using the newer dash and older bezel might look okay, but I can't tell your for certain because I've never tried that combination.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!! Last edited by wilkin250r; 06-30-2015 at 09:34 PM. |
Re: Dash Question
Both of my 78 is in the door jam
78K & 79C Jimmys
Re: Dash Question
my 78 vin is jam
my 79 vin is dash I'm using 89 pad 78 cluster/bezel it looks fine,yes the other way it leaves a funny gap. and the headlight switch and wipers mover with later bezel, and yes the left dash clip has to go....
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Re: Dash Question
Thanks for help folks.
