Old 12-11-2010, 09:35 PM   #51
Matt's k5
BLAZER THIRTY!!
Matt's k5's Avatar
Re: Jeep Coil Spring Drop
NO! I installed mine and it dropped it 5 inch's but if i stand in the bed it hit's the bump stops and i weigh 340 , but rides nice and looks awesome,i don't haul with it , Matt
49 chevy 5 window 20 year project (sold)😟
57 ford fairlane (dad's car never got to it before he passed away R.I.P I LOVE YOU DAD.)
62 GMC 305 V6 custom L/B
72 HIGHLANDER K5 BLAZER 2nd owner
71 K5 MAMMA'S RIDE!
63 GMC 4X4 305 V6
62 GMC SHORT BED SERVICE BODY V6 (STUMPY)
74 GMC CUSTOM 1500 L/B
Matt's k5 is offline   Reply With Quote
Old 12-12-2010, 12:16 AM   #52
StevieC
so I guess picking up a load of alfalfa an hour from home is out of the question
StevieC is offline   Reply With Quote
Old 12-12-2010, 01:34 AM   #53
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
haha unless ya wana ride bumpstops!
stock front
jeep springs rear
John
1999 Toyota Tacoma 4x4
Old 02-18-2011, 01:24 AM   #54
-sean-
Just wanted to add a note to this thread about the rear Jeep TJ/LJ springs.
There are four different versions of the springs that were used from 1997 through 2006. These are the ones that can be used on the C10. Similar rear springs could be found on the Jeep Grand Cherokee ZJ. All four versions are the same length wise but vary in rate.
The only way to tell them apart is by the color coded tags that are on the springs from the factory, they read as follows:
103AA (or 3AA) 130lb.
104AA (or 4AA) 140lb.
105AA (or 5AA) 150lb.
106AA (or 6AA) 160lb.
The colors on the tags can vary and the rates are "ball park" at best.
-sean- is offline   Reply With Quote
Old 02-18-2011, 09:01 AM   #55
oldblue1968chevy
Hmm
Good info.
John
Old 02-18-2011, 12:06 PM   #56
AllenKarber
Originally Posted by greenmtnboy View Post
FREE vs cheap
We all know drop springs are relatively cheap, but free is better.
As a WARNING FYI Here is mine with front springs cut TOO MUCH
I cut 2 full coils, then ended up with rubber spacers under the springs and some 1" bumpstops in place of the stock ones. In hindsite 1.5 coils would probably be ok.It rides like crap and bottoms out, but it was FREEEEE and allowed me to save my $ for '32 ford parts
I got a set of wrangler springs for the rear for free but have not gotten around to installing them yet.
I cut 2 coils off my stock springs,and boy was it low. It looked awesome,but the ride was pretty stiff,and I was always smashing my headers!
AllenKarber is offline   Reply With Quote
Old 02-18-2011, 12:14 PM   #57
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
The ride is real rough with cut springs. I did that once too.
This Jeep spring mod looks like something to do in the near future. What is used to hold them in place? I have cut coils welded in the rear now from the PO. The ride is not too bad in the rear, but would like it smoother.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 02-19-2011, 11:27 AM   #58
63 & 64 Bowties
and a few others
Originally Posted by degree01 View Post
63&64 Bowties, was that stock rear springs from a 70's Chevelle?
Yes, stock.
a newer pic of the same truck....
Bill US Army Vet -193rd Infantry
BlueRidgeMuscleCars.com
“The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi
63 & 64 Bowties is offline   Reply With Quote
Old 02-19-2011, 11:47 AM   #59
oldblue1968chevy
Are chevelle springs any 'stronger/thicker' than jeep springs? (I like the drop of the jeep springs but not the hauling capacity).
http://67-72chevytrucks.com/vboard/s...d.php?t=437582
Shock relocators on the cheap too...
John
Old 02-19-2011, 12:56 PM   #60
firefighter736
firefighter736's Avatar
Originally Posted by 63 & 64 Bowties View Post
Yes, stock.
That looks awesome... I see the stock springs for the Chevelle can be had on RockAuto for about $55-65. How does it ride? Bottom out like crazy? Did you relocate your shocks?
How is the front lowered, if you don't mind me asking.
firefighter736 is offline   Reply With Quote
Old 02-19-2011, 01:41 PM   #61
63 & 64 Bowties
and a few others
It rode great. I would imagine that the rear weight of our trucks and a Chevelle are about the same.
On the front, I cut 1.5 coils and cut off the bump stops on the LCA's. I sold that truck about a year ago, but I wouldn't recommend the coil cuts that much just because it puts the LCA's too close to the ground. If you're considering cutting coils, read this first....
http://webrodder.com/article.php?AID=582&SID=16
Old 02-19-2011, 03:51 PM   #62
paul63c10
so in english.... what do i need to drop the front 2 inches without cutting.
paul63c10 is offline   Reply With Quote
Old 02-19-2011, 07:51 PM   #63
oldblue1968chevy
Drop spindles, 'lowered' coil springs, air bags
cut 1 coil off and you'll be fine
John
Old 02-19-2011, 09:02 PM   #64
daverod
SSN 706
daverod's Avatar
jeep spring in the rear and a c notch. Put 7 sheets of 3/4" plywood in there today. Rode sweet no bump. Front coils cut about 2 removed the bumps and the brackets.
daverod is offline   Reply With Quote
Old 02-19-2011, 09:49 PM   #65
Surfdaddy
Surfdaddy's Avatar
Can you add air bags inside the springs to help carry the load. Just like air shocks of yesteryear? Set up the same way.
1961 GMC. Start date 1/20/2011
Past projects:
1958 Fleetliner 14ft Runabout
1966 Caprice 2dr
1970 VW Squareback
Surfdaddy is offline   Reply With Quote
Old 07-02-2015, 10:29 PM   #66
Paw
New guy here:
Are you guys using stock shocks ? with jeep rear springs and cutting off 1 coil on the front coil spring
Thanks Paw
Paw is offline   Reply With Quote
