Re: Hellwig airbags for K10
Originally Posted by special-K
I would mount onto the axle as usual and space against the frame. Is it an "L" for the top bracket (bottom/side of frame)? You could use 2" square tube on that. I have only used Air Lift brand because they are the ones who always specialized in such things before other companies decided to
That's what I have typically seen K. Either a spacer is used on the top mount or the whole top bracket is redesigned with the needed spacer built in.
Steve
1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's
